Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
HOW TO: ETS Intake and ETS UICP Detailed Install Guide
Old Apr 29, 2013 | 11:24 PM
  #46
CritikalWang's Avatar
Originally Posted by CRooKeDCoP
I am having problems finding the second bolt to install the heat shield anyone else have a problem with it ? 2012 GSR. I will take pics tomorrow when it's not raining. Intake install went well other then the heat shield. Car sounds great now even sounds quieter at hwy speeds. No drone from stock anymore.
Heat shield will mount:
1) On the filter
2) The 10mm bolt you took off on the RHS of the stock filter box.
Hope that answers your question
Old May 14, 2013 | 11:55 AM
  #47
wowitswil's Avatar
for some reason when i bolt in the maf adapter to the oem gasket...it doesnt tighten all the way in unless it gets forced out of shape....should i leave it loose or should it be out of shape?!?
Old May 15, 2013 | 07:13 AM
  #48
linkbeat's Avatar
If you're talking about the shape of the black plastic piece of the stock MAF that bolts to the velocity stack then I have the same issue and its nothing to worry about. The edges are tight against it but the middle isn't.
Old May 24, 2013 | 05:23 AM
  #49
wowitswil's Avatar
o ok...i just took it apart and reinstalled...alot better now...apparently i was have some leak at that area...
Old Jun 1, 2013 | 09:02 PM
  #50
Brandon982's Avatar
Installed this today! Holy crap sounds amazing! Only problem I ran into was step 10. I just replaced the whole line instead of tapping into the other one hopefully that doesn't cause any issues?
+1 ETS Intake
Old Jun 4, 2013 | 02:38 PM
  #51
NOSintake's Avatar
Amazing install guide. I used this a few weeks ago and everything was spot on. Being my first car I've modified and this being my baby, I was scared to do it, but this guide made everything a walk in the park. Thanks for all the hard work!
Old Jun 6, 2013 | 10:31 PM
  #52
wildave's Avatar
will the plastic cover taken off in step 2) fit back on again after the intercooler piping install ?
Old Jun 8, 2013 | 05:22 PM
  #53
sun_ice4's Avatar
Just noticed its missing in the last pic. Yes, it fits back on perfectly.
Old Jun 13, 2013 | 10:43 AM
  #54
AGinHD's Avatar
Awesome write up! Installing my intake & UICP this weekend !!
Old Jul 2, 2013 | 03:25 PM
  #55
<3voX>'s Avatar
Yeah great product, i replaced my AMS intake with ETS, fitment was good, the only problem i had was the heatshield.
Old Jul 3, 2013 | 04:42 PM
  #56
WoozZy_Woo's Avatar
Great Thread!
Old Jul 5, 2013 | 07:07 AM
  #57
<3voX>'s Avatar
does it look like this? i will re-install mine again, fitment looks ok, but filter is too close to the head light.
Attached Thumbnails HOW TO: ETS Intake and ETS UICP Detailed Install Guide-dsc00807a.jpg
Old Jul 7, 2013 | 10:06 AM
  #58
ETS Michael's Avatar
Should look like this. 1 on the back of the MAf and the other on the rail.
Old Jul 7, 2013 | 10:36 AM
  #59
sun_ice4's Avatar
Somethings not pushed in as far as it should be... MAF, housing, filter, even the turbo inlet may not be pushed all the way down. Loosen stuff, and semi start over. Fitment on the ETS intake is perfect.
Old Jul 8, 2013 | 09:14 AM
  #60
linkbeat's Avatar
My guess is that the coupler between the intake and MAF housing isn't pushed onto the intake as far as it needs to be. There's very little room for error at the turbo inlet.
