Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
HOW TO: ETS Intake and ETS UICP Detailed Install Guide
Old Oct 3, 2013 | 05:21 AM
  #61
tkromer's Avatar
Gettin ready to do this either tonight or Saturday. Is this as easy as it looks? Like 30 minutes? I can budget an hour and a half tonight, but I don't want to get the job halfway done.
Old Oct 3, 2013 | 09:15 AM
  #62
ETS Michael's Avatar
I would say if your a novice an hour to hour and a half should be enough time to pull the upper pipe and intake and install an upper pipe and intake. It's pretty straight forward. Honestly it will prob take you around 30-45 mins.
Michael
Old Oct 3, 2013 | 09:28 AM
  #63
tkromer's Avatar
Thanks! Not even doing the UICP today, just ordered that.
Old Oct 4, 2013 | 04:03 AM
  #64
tkromer's Avatar
Just for anyone curious, it took me about 55 minutes, which included about 10 minutes to jack up the car and pop the undertray when I dropped my 10mm wrench. Intake only, UICP would have certainly added another 15-20 minutes IMO. Install was super easy though. Thanks again to the OP for the great directions and ETS for the great product.
Old Oct 8, 2013 | 11:04 AM
  #65
newevoxguy's Avatar
Thank you. I did mine today took about an hr. Now it sounds awesome and perfect fit
Old Nov 23, 2013 | 05:22 PM
  #66
frenchfry675's Avatar
Originally Posted by CRooKeDCoP
I am having problems finding the second bolt to install the heat shield anyone else have a problem with it ? 2012 GSR. I will take pics tomorrow when it's not raining. Intake install went well other then the heat shield. Car sounds great now even sounds quieter at hwy speeds. No drone from stock anymore.
I'm sure you already figured this out but I had this issue to. The bolt that's used for the stock box can't be used for the heat sheild cause it's to long and not threaded all the way. I used one of the oem mass air flow bolts for the heat sheild since you don't use them for anything. Other then that one issue it was a awesome write up and saved me a ton of time. Thank you op. I was also very happy with the quality of the parts really top notch. And 15% off right now
Old Dec 2, 2013 | 11:04 PM
  #67
Psycho719's Avatar
Just installed my intake today and dropped my short flat head lol. Didn't bother removing undertray as it probably fell somewhere on my test drive lol. Install was straight forward. However, I did have trouble using the supplied BOV hose. It was tough getting it in all the way on the nipples (sounds dirty lol). It's on there but not super flush to the bottom. I used zip ties and went out for a drive and everything sounded great and no weird boost leaks or idling issues. One other thing to note is make sure you use the right clamps on the couplings. I thought they were all the same size and when it came down to putting a clamp on the MAF the clamp was too small. I had them switched around and had to mess around with it. Also those of you having trouble installing the heat shield make sure you use the provided studs. And tweak the MAF housing to align with the shield.
Oddly enough the hardest part was removing the stupid screw type clips. It wouldn't pop the screw up and I was getting frustrated. Removing the hoses wasn't much of a challenge after heating it up with a blow dryer.
I will be installing the UICP next when it arrives Wednesday. I'll get some pics tomorrow when there is day light.
Old Dec 5, 2013 | 05:49 PM
  #68
Psycho719's Avatar
Mine installed, intake slightly touching red battery terminal. Can't really angle it away.
Old Dec 6, 2013 | 04:02 AM
  #69
Mine was close to at first. Loosen the all the hose clamps and keep adjusting until it doesn't touch. Mine is only like a 1/4 inch from touching the red terminal cover.
Old Jan 3, 2014 | 02:14 PM
  #70
Evo82's Avatar
great help...thanks
Old Jan 3, 2014 | 02:16 PM
  #71
Evo82's Avatar
did you have to do a tune up after? i just ordered mine should be here next week
Old Jan 5, 2014 | 10:43 AM
  #72
Tommy2jz's Avatar
Very detailed guide. Thanks!
Old Feb 9, 2014 | 07:58 PM
  #73
William Naing's Avatar
http://i1196.photobucket.com/albums/...ake-UICP11.jpg
Need help on the boost control solenoid lines. Anyone have picture where these go? ~thank
Old Feb 19, 2014 | 03:17 PM
  #74
powerman00's Avatar
great write up, im going to be using this as soon as my ets intake and uicp arrive next week.
Old Apr 6, 2014 | 08:17 AM
  #75
2x4's Avatar
2x4
Great thread thanks! I hade a boost leak. Problem was I was clamping on the outlet pipe against the large bead at the end where the air comes out. After reading this, I pushed the hose down a little and slightly over the smaller bead. Then I clamped against the smaller bead. Seems backwards compared to all the other couplers but it works.
