Help building my engine for a bigger turbo.
im trying to get a bigger turbo but i know that i need to set up, prepare or build up my engine to support it. the problem is idk what i need to do or where to start. and also any suggestions on what to get im going for 450-500 on pump. thanks.
Imagine a deck of cards, each card is a modification to your engine, now deal a couple hands. Each result will be different.
I will say that there have been a number of folks pushing 450-500 hp on stock internals, then again others have blown their motor at 400 hp.
https://www.evolutionm.net/forums/ev...ock-stage.html
https://www.evolutionm.net/forums/ev...ock-block.html
https://www.evolutionm.net/forums/ev...r-500awhp.html
So it has been done reliably with guys going well over a year pushing that kind of hp. It all comes down to how it's modded and tuned. If you want the engine to be absolutely bullet proof then yes, beef up the internals. However, IMO 450-500 seems a bit low for the kind of money you would be pouring into the car.
"Beefing up the internals" would include:
Sleeved cylinders
Forged pistons
Forged rods
High performance rod & main bearings
Head stud kit
All of which would set you back thousands of dollars. AMS charges almost $2,000 just for the sleeved block....that's with a core. Their stage 2 is around $5,000. Figure almost another $2,000 for the head. Then you have a bullet proof foundation...though nothing is really truely bullet proof.
Sleeved cylinders
Forged pistons
Forged rods
Head stud kit
Sleeved cylinders
Forged pistons
Forged rods
Head stud kit
Sleeved cylinders
Forged pistons
Forged rods
Head stud kit
My advice would be to go or at least contact a quality trusted shop (I believe ETS should be fairly local to you), tell them what you want to accomplish, how you will use your car (DD, autox, track, drag..) and what your budget is and they will lead you down the best path to get there.
cmiller10
Jul 25, 2016 06:32 PM
chowetime
Mar 28, 2016 09:29 AM
