Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Break in question!
Old Jul 6, 2013 | 09:30 AM
  #31
Jake.barratt's Avatar
I purchased the car new with 300 miles all shift past 5k rpm lol. So id say my car has been abused since day one. fortunately I work at the dealership I bought it from so that why I got a free warranty clutch.
Old Jul 24, 2013 | 08:50 AM
  #32
Ben Ingraham's Avatar
Synthetic/black oil
So...alot of questions for conventional vs synthetic oil from the factory and what to use after the first oil change.
I agree with the comment for cost of conventional oil for manufactures being less then synthetic. Could they come from the factory with conventional oil? Plausible. Not like likely. With conventional oil vs synthetic, seals, grommets, fittings, will not absorb/seat the same. Synthetic oil is more refined, it doesn't have alot of the impurities of conventional oil. It lasts longer, better for the components, doesn't build up as fast, on and on and on.
If you change your oil or have someone do it for you and only use conventional you may get a little more wear and tear in your motor. Not a bad thing really, it's just what happens to a car, esp. cars like the Evo.
Synthetic oil will likely help in reducing the time that it takes to witness wear and tear, but again this is what happens.
This is a fact and you're welcome to try it. If you've been running conventional oil in your car and have been the whole time you've owned it, then change to a synthetic, I would advise you to have a drip pan or dry sweep ready in the morning after your car has sat over night. The seals will leak due to the synthetic oil being finer and less likely to build up than ole' faithful conventional oil that your dad used in his '76 Ford one ton.
As far as oil turning black. Turbo motors are notorious for oil turning black before an NA motor would. Things move faster. The turbo is cooled/lubricated by the oil. Google "coking" and you will find out why it is a good idea to idle your engine after a long or hard drive in your car. (Hint, buy a turbo timer).
Old Jul 24, 2013 | 11:28 AM
  #33
zebra4's Avatar
The old 76' Ford one ton might leak after throwing synthetic in it, anything that is newer can be switched without problem. I have done this lots, on almost every vehicle i have owned that came with conventional oil and never had any leaks/problems after switching to synthetic. Also, any major oil manufacturer (Valvoline, Mobile 1 ect.) states that switching will cause no harm or problems whatsoever.
Old Aug 26, 2013 | 09:07 AM
  #34
EdMr44's Avatar
I just bought a 2014 mr would oil change at 1000 miles be a good idea? The dealer told me to bring it in at 5k but then again theyre idiots at the dealer
Old Aug 26, 2013 | 09:12 AM
  #35
Kracka's Avatar
Changing the oil so soon would just be wasting money. Change it around 5k as the maintenance schedule states.
Old Aug 27, 2013 | 07:13 AM
  #36
vegittoss15's Avatar
1000, yes. 5000 is a bit high for my liking though.
Old Aug 27, 2013 | 08:43 AM
  #37
Sev's Avatar
Sev
Oil Change @ 1K, then every 3K. Notchy shifting is normal in the X. I "broke in" my X after ~2K.
Old Aug 28, 2013 | 03:30 PM
  #38
st0k3d's Avatar
Break it in hard.
Old Mar 28, 2014 | 02:23 PM
  #39
evostanman's Avatar
Broke it in the second i felt the dealer
Old Mar 28, 2014 | 05:51 PM
  #40
Thomar's Avatar
You're nasty. Stop that.
ohhgyeahfasho
Mar 6, 2014 04:46 PM
itsbonestock
Aug 28, 2012 12:11 PM
Kendogg
Feb 21, 2012 03:04 PM
devinramen
Driving Techniques
11
Oct 12, 2011 02:44 PM
RomansEVO8
Sep 7, 2006 02:10 PM
