Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Stock Downpipe Removal
Old Nov 16, 2013 | 08:21 PM
hamburger_train's Avatar
Today I removed the stock downpipe in my 08 in order to install the AMS turboback exhaust system. I didn't break any bolts
Here is a list of tools I felt were the most helpful and effective. They aren't all the tools, but they are what I absolutely had to have to do this.
-14mm sockets in 3/8" and 1/2"
-extensions in varying lengths. the most useful was 20"
-14mm swivel socket
-14mm flex-head ratcheting wrench
-3/8" ratchet
-PB blaster
-high heat anti seize
-2 ramps
-2 jack stands
-second set of hands would be helpful
The downpipe removal is pretty straightforward. I started first by backing my car up onto ramps and then removing the strut tower bar. This will allow access to the heat shields and most of the bolts on the downpipe.
I then put the front up on jack stands and removed the passenger's wheel. Other writeups mention the "left" side. I assumed that meant driver's side, alas, nothing can really be accomplished from that side. There are a few bolts that are easily accessible from the passenger wheel well, as well as the CV boot heat shield. I'd recommend removing the CV boot heat shield as soon as you take the wheel off. I removed the exhaust system piece by piece all the way up to the downpipe.
Next I removed the manifold heat shield and the firewall heat shield.
The heat shield surrounding the downpipe consists of 2 pieces. It needs to come off before you can access all of the bolts.
Before you start to remove these bolts, hit really well with PB blaster. You can remove most of the bolts on this side from atop the engine. The lower bolt above the CV joint (not pictured) is easier to get from the wheel well using a swivel socket and extension. The hardest bolt, actually a nut and stud, is circled in blue in the pic, though it's not visible. I used the 14mm flex-head to get this one.
Here is an image from below the car of the 2 lower bolts that can be accessed easier by the wheel well and by removing the CV joint heat shield in blue.
So yeah. That's pretty much it. I was a little overwhelmed by reading a lot of the other writeups, seemed like there was a lot of clutter, so I wanted to share my experience. It's a fairly simple job, just a few bolts that require some creativity, and beer
Here's a link to my
Cheers!
Old Nov 17, 2013 | 11:28 AM
beetle_orange's Avatar
How many miles on the car? Seemed too easy compared to what others have said.
Old Nov 17, 2013 | 01:09 PM
82k. It's really not that bad. I mean it's a pain in the ***, but nothing too tricky. This is the first mod I've done on this car, I've only changed the oil, rotors/pads, and spark plugs since having it. Having a second person is key. I did it myself, but having someone to guide the sockets and help with the downpipe installation would have made it a breeze.
Nice VW btw, I had a 72 orange squareback like 7 years ago. Fun little car!
Old Nov 17, 2013 | 05:43 PM
Thanks on the compliment on the VW, it's my one true love.
Very interesting to note especially since you got all of them off even with a such high mileage car unlike some that have such low miles yet break a bolt or two.
Old Nov 17, 2013 | 05:59 PM
I'm assuming most people who have attempted this haven't had the same misfortune of removing headers/heads from a 66 F100 FE motor like I have. I think there were 1/2 of the bolts left when I put it back together! Needless to say, I was very cautious doing this.
Old Nov 18, 2013 | 05:21 AM
Wow that's a really clean squareback, why did you get rid of it? My wife wants one actually.
Old Nov 18, 2013 | 10:06 AM
I was 18 and didn't want to spend the time to keep it running. It kept burning up alternators. Kind of a Frankenstein of a car. Hard to find parts!
Old Nov 24, 2013 | 02:43 PM
nomad's Avatar
How long did it take to remove the down pipe? I have an ams downpipe that I want to install but have only read the horror stories about removing the stock downpipe
Old Nov 24, 2013 | 02:48 PM
701evo's Avatar
Man evo 8/9s are a lot Easyer to put a new dp on lol
Old Nov 24, 2013 | 05:16 PM
I would reserve a few hours. Make a world of difference with the passenger wheel off, the extension and swivel socket, and the flex head ratcheting wrench
Old Nov 24, 2013 | 05:17 PM
Yeah I've heard :P
Old Mar 3, 2014 | 10:47 AM
Just pulled the ams widemouth dp to ease the tranny removal.
Took all of 15 min. So much easier when you've done it before!!
Old Mar 3, 2014 | 07:40 PM
What happened with the trans?
When are you coming to help me?
Old Mar 4, 2014 | 03:14 AM
What happened with the trans? When are you coming to help me?
Doing the clutch. Lol you got it man. It's literally 5 bolts!
Old Mar 4, 2014 | 10:35 AM
yeah plus 1 nut
kozmic27
32
Oct 28, 2019 04:39 PM
joel(PA)
66
Mar 9, 2018 06:10 PM
DeweyD
Apr 26, 2015 07:08 PM
02ES=>09RAL
Nov 2, 2014 06:50 PM
►EvolutionX◄
21
Oct 11, 2009 04:54 PM
