Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Newbee need help on DIY 30K maintenance
Old Apr 23, 2014, 02:14 PM
okyu5632's Avatar
Post Newbee need help on DIY 30K maintenance
Hey Guys, i've been reading around for a while. learned a lot from here! awesome forum!
Now 30K service is coming soon, I'm planing to exercise a little bit and try to do as much as i can to avoid crazy charges from stupid dealer.
background: haven't ever changed oil in my life. but its time to start doing it!
i learned that i can do following:
engine oil & filter / air cleaner filter / cabin air filter
im not sure if i can do : transmission / transfer case/ differential/ axle/ coolant/ belt
and i don't have a workshop! so no lift, don't even have jack stand yet. start from 0.
any suggestions from pro are highly appreciated!
BTW, not really heavy use except once a month go for a track run.
Old Apr 23, 2014, 02:35 PM
Thomar's Avatar
Well, an oil change is a good place to start. It's very easy. And changing transmission oil is also just as easy. Just drain and fill.
I would suggest you get the tools you need, including a torque wrench and maybe a set of ramps, or jack and Jack stands.
And then, refer to the 'how to' section of this forum. Lot of info there on how to do maintenance.
And best of all, no exercise required at all! Unless you're really weak.
Old Feb 19, 2015, 08:22 PM
e85_evodiction's Avatar
youtube
golgo13
433
Nov 1, 2023 07:39 AM
nuckenfoob
Jun 7, 2017 01:06 PM
hutch959
Sep 27, 2016 05:39 PM
pckiller00
Sep 24, 2015 11:40 AM
HimynameisWillzyx
Aug 21, 2010 10:57 AM
Quick Reply: Newbee need help on DIY 30K maintenance
