Good visibility with LED map lights?
has anyone changed the 2 map lights to blue leds? If so, is it easy to read things? For example at night if you needed to pull out some papers from the glovebox and read them, is it bright enough for that?
yea i know white would look the best, but then you would have to set it so that just the center dome light comes on when you open the doors, otherwise you would have 2 white lights and a blue on at teh same time. unless the blue center dome light is bright enough to light up the car.
96 leds, no problem! Its like daylight!
https://www.evolutionm.net/forums/sh...97463#poststop
t5caveman
Apr 7, 2012 10:10 PM
