So my 2011 Evo X Fog lights...
Old Dec 11, 2011 | 05:32 PM
dtfrost5's Avatar
burned out or didn't work so I set out to replace them with another set of 11's per the manual. I pull off the bottom section and this is what I found:
http://s1191.photobucket.com/albums/...3DIMAG0025.jpg
It was not the configuration I was expecting and I could not get the light out unless I disconnected the wire harness.
Need some help replacing these, but I not sure with what?
Any help greatly appreciated.
Old Dec 11, 2011 | 05:50 PM
thisisagame24's Avatar
its an aftermarket HID kit. test the ballasts out to see if they went out, it might just be that instead of the bulb
Old Dec 11, 2011 | 07:22 PM
dtfrost5's Avatar
how do you test the ballast?
btw, i think both went out at the same time. seems coincidental.
Old Dec 11, 2011 | 07:24 PM
you can test the ballast by just powering up the bulbs with jumper wires or something like that. if both went out i would go over the wiring to see if something came loose
Old Dec 11, 2011 | 07:32 PM
dtfrost5's Avatar
thanks, i will pull it a part again next weekend.
Old Dec 11, 2011 | 09:54 PM
iEvolutionX's Avatar
Which side did the fog light stop working? The simplest approach would be to plug the bulb into the working side and see if the bulb turns on.
If it does, then the ballast is your problem, if it doesn't then you know its the bulb.
Old Dec 12, 2011 | 12:45 AM
AUTO Design's Avatar
Switch the bulbs around then you will know if its bulb or ballast. Also check your fuse!
Old Dec 12, 2011 | 04:35 AM
dtfrost5's Avatar
Both bulbs went out at the same time and I was not able to pull the bulb out. It appeared that I would have to disconnect part of the wire harness. Checking the fuse shortly.
Thanks again.
Old Dec 12, 2011 | 07:17 AM
dtfrost5's Avatar
fuse was bad, replaced, and still not working...
testing the ballast this weekend.
Old Dec 12, 2011 | 07:28 AM
ugakirk's Avatar
Did you buy a really cheap Ebay set of HID's for the fogs or something? I mean, the screws/rivets are all rusted. Maybe some water got in there and fried them?
Old Dec 12, 2011 | 06:49 PM
dtfrost5's Avatar
I did notice the rust and thought, what a bunch of cheap mfs. Anyway, the aftermarket fogs came with the car and they did work until we had some thick snow in Jersey back in October. I tried replacement fuse today and it burned that one out too.
As you know finding a short is painful, now I'm thinking replacement or delete unless there is a simpler way to figure this out.
Old Dec 12, 2011 | 06:55 PM
ugakirk's Avatar
I would either just delete them and buy the JDM RS covers or buy some better HIDs. I think they are some really cheap ones. Is there anyway you can go back to stock?
Old Dec 12, 2011 | 07:09 PM
dtfrost5's Avatar
I am not sure stock is an option, but when I pull it apart this weekend I will check that out option since I have some 11s. Since the HID harness appears to be a plug and play, going back to stock should be an option. Thanks, that was helpful.
Old Dec 12, 2011 | 09:15 PM
We sell the high quality HID kit that will not flickering or having power up issue guarantee!!!
Old Dec 13, 2011 | 01:01 PM
dtfrost5's Avatar
found these on the net that appear to match the one's in there now
http://www.alibaba.com/product-gs/37...n_Ballast.html
based on a quick review of these, they will be coming out this weekend and will revert to the 3000k stock bulbs I have until early January where its either delete or upgrade with real set up HID xenon conversions.
thanks again for all the input
dtfrost5
Jun 21, 2016 08:23 AM
dtfrost5
Apr 29, 2016 03:14 PM
dtfrost5
Jan 18, 2016 08:30 AM
dtfrost5
Aug 24, 2012 10:32 AM
4g64t_dohc
Dec 15, 2011 02:01 PM
