Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Any opinions on Ferodo's DS2500 pads?
Old May 4, 2009, 02:50 AM
EndlessRed's Avatar
i've been scouring for a set of pads that would fit the x without adaptors, for light track usage. it looks like ferodo's DS2500 is the only current option (that i can find at least). does anyone have them on the x currently? how is the performance, noise, and brake dust?
Old May 4, 2009, 03:32 AM
de_pellerin_luc's Avatar
Also found a set on rallysportdirect.com and would like to know what people's thoughts on performance and brake dust were. Noise isn't as much a concern.
Old May 4, 2009, 07:33 AM
Nammy's Avatar
I've had these on my car for the last 1000 miles or so, including one autocross. I swapped my rotors and lines when I changed the pads as well, so I don't have a good idea of what difference the pads alone would make. The brakes work great, though, with a lot of initial bite. There is still some squealing once they heat up and under light braking, but the dust is significantly less than the stock pads.
Old May 4, 2009, 07:37 AM
TxEvo8's Avatar
I've run them on the street and on the track and honestly they did not hold up well for me on the track. Something more agressive like a Hawk HP+ works better on the street and on the track, although they are noisy..
Old May 4, 2009, 07:44 AM
MarkM's Avatar
I find them excellent, good compromise between stopping power and disc wear/noise, much better than stock, not much dust, no brainer for me
Old May 4, 2009, 07:45 AM
goofygrin's Avatar
I have about 9000 miles on them.
Pros:
- they do work ok for light track duty and autocross
- not as dusty as the OEM pads
Cons:
- squeaaaaaaaaaaal
- Once you let the smoke out (overheat them), they're done
- pad transfer to the rotors is really, really heavy
- they are semi-aggressive on the rotors
TxEvo8, the HP+ suck IMO. Noisy and they don't brake all that great. I for SURE wouldn't run them in the X on the track. I've not found a pad that I really like yet.
Old May 4, 2009, 07:58 AM
MarkM's Avatar
Originally Posted by goofygrin
Cons:
- squeaaaaaaaaaaal
Have you copper greased the rears? Didn't have any squeal from mine at all
Old May 4, 2009, 08:02 AM
goofygrin's Avatar
What *haven't* I done to try and counteract the squeal?
And that's just the fronts.
The rears (I'm using the girodisc adapters since I got them a while ago) squeal TERRIBLY. Hopefully the ones made for the X work better.
vboy720
Aug 1, 2013 10:45 AM
xXANCHORMONXx
Mar 13, 2013 10:03 PM
overdrive1
Mar 6, 2013 07:34 PM
KOOLER
Jun 3, 2012 02:34 AM
Gusl
10
Jul 12, 2010 07:22 AM
Quick Reply: Any opinions on Ferodo's DS2500 pads?
