Lowering Springs and effect on handling?
I bought my X second hand and the person before me put Eibach lowering springs on it. I currently DD the car but will be hoping to get to an open track day or two this summer.
My question: do the lowering spring effect the handling of the car negatively? Do they decrease the life of the factory suspension? Recommendations for equal to or better the suspension mods vs. stock.... Less then $1500
Thanks
Thanks
Thanks
Thanks
Depends on the springs. Some lower the car too much for their rate, so what you lose in roll-center height isn't made up for elsewhere. But Eibachs are OK.
Again, it depends in the springs. The two main ways that lowering springs hurt the suspension is by allowing the car to bang the bumpstops and by being too stiff for the rebound seals. As above, Eibachs are OK.
In that price range, KW V3s.
I'm interested.
@: Iowa999 - so I should feel comfortable driving the car under this setup, thanks for the info. Just so I understand better, what about the Eibach springs make them okay to use?
Side note, what would you recommend for brake modifications? Pads, rotors, etc... Budget conscious but not afraid to spend if it makes sense.
I was thinking of getting cross drilled and slotted rotors along with aftermarket pads. Again, car is DD with potentially 2 track day events over the summer.
Thanks for the knowledge!
If you look at the sticky on springs, you'll see that the Eibachs aren't much stiffer than stock. This is why I say that they aren't going to blow the rebound seals in the shocks. Yes, you might be a bit under-damped, but you won't hurt the shocks.
As you know, they don't lower the car too much. The best way to see this is to climb under the nose and look at the lower lateral control arm. If it's angling down from hub to chassis, the car is too low. If it's flat, that's not great, but OK. If it angles up from hub to chassis, you roll center is still nice and high.
As to brakes, I'm not the one to ask, as I have small, rally brakes. But, in general, I'm not a huge fan of cross-drilled, slotted, uber-fancy rotors. A set of Centric blanks that I can have turned or just throw out is my preferred approach. Your real issue is going to be getting pads that won't fade on the track but also don't make sounds like a hog-farmer's abattoir on the street. [I'll wait while you google.] That's where you need a real expert and/or two sets of pads.
about handling, dont expect too much
i have an Eibach springs on the KYB struts. ( GSR suspension)
And i just did some spirited driving , well... feels as a stock suspension and very loose over 100mph even on highway.
We did cut the rubber bump stops, so the suspension will have a longer travel. As Eibach recommended. I think you must do that. So check if they did when they installed it. if not you can cut it with a box knife very easy. Slow speed they feel OK, and give you a feel of being great or better then stock. When you put them in a test , they seems to me just as good, maybe a bit better then stock., nothing major. But nothing as good as a GOOD coilovers would give you.
Anyway, KW V3 would be a lot better option, if you looking for handling vs springs ( ANY).
i have an Eibach springs on the KYB struts. ( GSR suspension)And i just did some spirited driving , well... feels as a stock suspension and very loose over 100mph even on highway.
How much did it affect ride COMFORT? I know that is a relative term since our cars have stiff suspension from the factory, but as a DD is it very noticeable?
Folks should be very careful about discussing ride "comfort" when one person has an MR and the other has a GSR. The Billies on an MR are not only better shocks in terms of strong and consistent low-speed damping that the KYBs on a GSR, they also blow-off cleaner and, thus, have a nicer ride. I'd hate for someone with an MR to be told by someone with a GSR how nice a certain aftermarket part was for them, only to discover that it made their own car worse.
evojay85
Dec 30, 2013 12:18 PM
senorguitar
Apr 24, 2012 04:20 PM
CtSilver03Evo
67
Mar 14, 2012 11:04 AM
