Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
enhancing ride quality
Old Jun 29, 2018 | 04:35 PM
LetsGetThisDone's Avatar
They typically go about the same as shocks on any other car. 60-100k miles depending on use. Less with lowering springs.
Old Jun 30, 2018 | 04:43 PM
DeweyD's Avatar
Originally Posted by rongdoer
Urethane bushings anywhere you can put them on. It doesnt make the ride more plush, but it makes the car take bumps in a more refined way, so it wont make such a big deal out of each little imperfection. The suspension is basically working more efficiently.
Is this a joke? I hope you are joking. If you are looking for better ride comfort urethane bushings are the last thing you would do.
anyway to answer OP, you could look into running softer sway bars. Cusco makes gravel sway bars that are softer than stock. You could also look for a sway bar bracket that gives you more leverage on the stock sway bar.
The other route may be to get some coilovers and run very soft springs with the dampers set to the softest setting.
A non performance tire with tall, soft sidewalks may improve the ride a bit.
also big pillows on the seat might help
evo'skickass
Jan 22, 2004 02:24 PM
ocasioa
May 8, 2002 07:48 AM
