Need some advice
Old Apr 11, 2006 | 09:02 AM
XK120's Avatar
Need some advice
Old Apr 11, 2006 | 09:48 AM
Warrtalon's Avatar
The TXS does not perform well on the Evo. The Hallman in-cabin works well, but yeah, you test it by turning knob then boosting. Same as you would with any MBC. I can tell you now that there's no reason to want to switch between "stock" boost and 20-21psi on the fly, because...well...stock boost is already 20psi, and there's no reason to run less than optimum boost on a daily basis. You won't end up using the feature at all, because you would only want to run higher-than-normal boost on race gas, and you won't be doing that except at the track (if ever), in which case you could easily turn up your boost on a normal MBC without messing with the TXS dual stage.
Btw, you will find that you have no need for an in-cabin controller either, because once your boost is set, that's it...you don't have to mess with it again except occasionally for minor adjustments as the weather changes. It only takes a few seconds to do it in the engine bay, and it's better to keep the vaccuum hoses as short as possible.
Old Apr 11, 2006 | 10:04 AM
XK120's Avatar
Thanks! That's all I needed to know
EvoTillIDie
Feb 2, 2011 09:01 AM
speedmaster747
Nov 2, 2009 08:11 AM
Evo_Wanted
May 19, 2007 09:17 AM
3000ways
39
Feb 27, 2007 07:05 PM
MRIX
13
Jun 7, 2006 08:24 PM
