Stupid question but... how to empty out the oil catch???
Old Jun 21, 2006 | 11:12 PM
youngs's Avatar
Angry Stupid question but... how to empty out the oil catch???
I just got my new "used" EVO 8 and went in for an oil change. First I went to pepbos, when I explained that the oil catch had to be emptied, they went blank, they had no idea what it was. So I decided to take it to the mitsu dealer. Fred Bean Mitsu dealer in PA. They also didn't know what to do. I thought that was strange because I know I am not the only EVO with a oil catch. But since I needed the oil change I just had it done. I did figure out that my oil catch didn't need to be emptied out at the time, but when the time comes, can anyone tell me how to?? I couldn't find a sticky for it.
Old Jun 22, 2006 | 06:58 AM
althemean's Avatar
Dude......if you cant figure that out and you went to pep boys with your car? Dont even work on the thing.
I dont run an oil catch can but it would seem logical that you unhook the lines and remove it from the car and just turn it upside down to let it drain unless there is a drain hole at the bottom. Use your head. Sorry for being rude......
Old Jun 22, 2006 | 07:19 AM
AutobonEvo's Avatar
^ ahahahah................ sorry man that was just to funny. Let me quote that.
Old Jun 22, 2006 | 07:21 AM
Ev0ikon's Avatar
Originally Posted by althemean
... unhook the lines and remove it from the car and just turn it upside down to let it drain unless there is a drain hole at the bottom. ..
I vote for the later
Old Jul 2, 2006 | 12:29 AM
youngs's Avatar
Question
well found out that you have o unscrew the tank from the car and empty it out, have to unhook the tubes. Not sure but have you seen and oil catch in an evo before ???? There is no way you can get to it from beneath the car. I have a CUSCO oil catch tank. Its only mountable near the backside of the engine. I'll post a pic later.
Old Jul 2, 2006 | 12:32 AM
EvoDan2004's Avatar
it is easy. guys be nice to him. not everyone can TURN A CATCH CAN OVER TO EMPTY IT OUT oops did i just tell you how to do it. man can someone come here to show me how to shift into second gear.
Old Jul 4, 2006 | 08:43 AM
MRaaron's Avatar
Wow, I'd think that since he posted a valid question in the Newbie forum he'd be entitled to answer without all the crap.
How about the "Evolved" members that come to help the newbies actually help instead of posting stupid replies just to build their post count. It would make for a more pleasant and productive forum.
Old Jul 4, 2006 | 08:57 AM
Kings Fan's Avatar
Is there a drain plug? Feel along the bottom of the can for it. If there is, just drain it from there. If not, you'll have to unmount it.
Old Jul 4, 2006 | 09:06 AM
carl's Avatar
i thought posts in the newbie forum didn't add to your post count
anyway, does your catch can fill up every 3,000 miles? if so, that seems like a lot of blow-by
Old Jul 5, 2006 | 09:51 PM
youngs's Avatar
Thanks, yeah I have to unmount the tank to drain it, it didn't have a drain plug.
have to undue alot of things to get to it tho.. but yeah thanks.
Old Jul 5, 2006 | 09:54 PM
youngs's Avatar
Exactly...
I'm just starting to learn about the car and its parts, I just loved to drive without knowing too much about the car itself. thats why I have lots of questions. Some just don't remember how stupid they were when they first knew about these things. Maybe they received the same treatment??? who knows
Old Jul 5, 2006 | 09:56 PM
youngs's Avatar
I just got the car without know when the last time they emptied it thats why. But no its not supposed to fill up every 3000miles..
Old Aug 23, 2006 | 06:11 AM
saiyanzzrage's Avatar
the clear thing on the side that you use to see the level of oil in the can is how you drain it. it unhooks, and the oil comes out from there
Old Feb 14, 2011 | 04:37 PM
dastallion951's Avatar
forget the jerkoffs response on here, ive got a cusco catch can easiest way to get it out is of course loosen clamps to hoses once you have them pulled off there should be a bolt or two that holds the catch can to the bracket support, loosen it dont lose the bolts pull under strut bar, flip upside down like other person said give it some good shakin most should come out, or at the very least, get urself an air compressor and shoot some compressed air in one fitting and residual should blow out the other end
Strictly Modified
47
Sep 10, 2014 10:43 AM
EvoDan2004
16
Aug 26, 2013 07:57 PM
Liqquid
22
Nov 16, 2011 10:12 AM
scary19
Oct 1, 2011 06:50 AM
taylorgang
Jul 17, 2011 04:47 PM
