cut o2 sensor wire
Old Feb 16, 2007 | 10:47 AM
Mitsu3's Avatar
cut o2 sensor wire
i installed my ams tbe with cat and i couldnt get the o2 sensor off the stock cat. So i cut the wire. What can i do now connect a new o2 sensor to the wires and plug it into my exhaust?
Old Feb 16, 2007 | 10:49 AM
Silk's Avatar
Follow the wire and there should be a clip some where that you can disconect the cut wire so you can put on a new 02.
Old Feb 16, 2007 | 10:50 AM
nikkadanny's Avatar
i just left it cut, and i'm waitting on a new rear o2 sensor
Old Feb 16, 2007 | 01:19 PM
DanJ's Avatar
You can by a generic 02 sensor and just wire it to the part you cut off, Or spend the extra $ and unplug the wire and purchase an oem 02 sensor.
Old Feb 16, 2007 | 01:30 PM
Mmelmann's Avatar
Yeah, the O2 sensor off my stock exhaust was a beotch to get off. It's hard to get a good grip on it.... you can't use a socket, and the damn heat sheild get's in the way. When I did use my man hands to get the thing off, it looked like the threads were almost damaged. And when I installed it to my Ultimate Racing test pipe... it was another beotch of a time.
Just talk dirty to it to get it out. When the time comes to reattach the wires, make sure you utilize some solder and some heat shrink for that gauge of wire. (Make sure you put the heat shrink tubing up the wire before you solder the wire heat shrink tubing doesnt work if you cut it length wise and then try to use your lighter on it) Don't mate the wires up with some cheap *** twist on style end cap. There is just too much water and crap to corrode the wire underneath the car.
Get mean next time. Go work out, sheesh.
Old Feb 17, 2007 | 05:52 AM
DanJ's Avatar
I would recommend going to your local autozone because they loan a 02 socket remover. It is basically has a slit in the socket that allows you to put it over the wires. Also I HIGHLY recommend putting anti-seize on the 02 sensor threads so when it comes again to removing the exhaust you won't get this problem
svt_lightning01
Jul 25, 2012 07:55 AM
veszett
Apr 10, 2010 04:54 AM
SwiftEVO
10
Jun 7, 2007 04:47 PM
psychlancer
04-06 Lancer Ralliart How To Requests / Questions / Tips
Feb 26, 2006 09:34 PM
deekay247
Dec 15, 2004 12:01 AM
