What clutch should I get?
Old Jul 9, 2008 | 11:02 AM
porsherules911's Avatar
Hey guys, posting this in newbie section since I don't have too much background on this stuff. My clutch is starting to catch right near the top of the pedal so I have a feeling it will start slipping soon and then time for new clutch. So I'm just preparing myself for when the time comes. Which clutch should I get? I think a lot of people are getting ACT clutches so I guess I will do the same. Not sure which ACT though. My car I'm not planning on pushing crazy power, maybe 350 whp max and torque same thing so I'd like something that can definitely handle that power. Also, how do I know if I need a new pressure plate or flywheel?
Old Jul 9, 2008 | 11:04 AM
IEXCELR8's Avatar
Exedy twin.
here is a poll..
https://www.evolutionm.net/forums/po...ts&pollid=2457
Old Jul 9, 2008 | 11:08 AM
ct9a_mr's Avatar
I have the TTP spec ACT 6 puck sprung on my MR and it works great. Definitly holds the power.
I put down 382 recently on a Mustang Dyno.
It takes a little getting use to driving it but its not bad at all.
Old Jul 9, 2008 | 11:24 AM
Originally Posted by IEXCELR8
So 300 ppl voted for ACT Street. Is the model number for this clutch MB7-XTSS?
Also, how do I know again if I need a new pressure plate and/or flywheel?
Old Jul 9, 2008 | 12:05 PM
landis507's Avatar
im thinking of going with the ACT street clutch with flywheel combo from lancershop.com it says it holds 450+ hp easy. and i no im not going that high but its prolly worth it. and i want stuff that works great together, so same brand clutch and flywheel
Old Jul 9, 2008 | 12:06 PM
TTP Engineering's Avatar
That is definately not the clutch you want. PM us with information about what your power goals are and how you most use the clutch.
Thanks
TTP
Old Jul 9, 2008 | 12:11 PM
landis507's Avatar
Thanks
TTP
so is the clutch i thought of a good one, i dont really launch from 5500 rpms, and usually normal driving, if not then fast shifting, i dont usually drop the clutch wen im shifting, at most 5 times a month(like i said at MOST, prolly not even that much) and my sig are my power goals
Old Jul 9, 2008 | 12:37 PM
Thanks
TTP
I'm a bit surprised you guys don't recommend that clutch. Why don't you recommend it and what would you recommend?
Old Jul 9, 2008 | 01:09 PM
Jedi_Gill's Avatar
FCOTM Winner
A Poll answers nothing.. Honestly.. research on here.. my personal opinion from knowing both the exedy twin and the quartermaster is that the quarter master is a the superior clutch.. I'll look for a link around here where people discussed it.
Old Jul 9, 2008 | 01:50 PM
landis507's Avatar
so what about the street clutch and flywheel combo from lancershop.com. is it any good for the mods ima have
Old Jul 9, 2008 | 02:00 PM
Thegame's Avatar
From the sounds of it for both you guys, a twin disk is overkill. With power levels around 350-400 whp and occasional track use, I would check out the following.
ACT HDSS, Fidanza 3.2, Spec Stage 2+, and Works clutch kit. I personally have owned both an ACT HDSS and a Fidanza 3.2.
Old Jul 9, 2008 | 02:19 PM
Sev's Avatar
Sev
Act
Old Jul 9, 2008 | 03:08 PM
landis507's Avatar
so the one i picked is good
Old Jul 9, 2008 | 09:46 PM
rocknsnoboarder's Avatar
I have the ACT streetlite clutch and flywheel kit and I love it.
The turbo spools a hair quicker and the clutch grabs really nicely but is still easy enough to drive on the street without breaking your leg.
Old Jul 9, 2008 | 09:54 PM
landis507's Avatar
so its a good clutch and flywheel? what about with the mods i have, will it still be good
