High flow cat and emission inspection?
Old Oct 23, 2008 | 04:33 PM
EriCS's Avatar
Question: Will a high flow cat stop me from passing emissions inspection?
Old Oct 23, 2008 | 06:47 PM
mrMTB's Avatar
Not sure how they handle it in NY, but here in TX an AWD OBDII car just gets hooked up to the code scanner to ensure there are no faults in the system. Given some of the cars I've seen from your area, I don't think you have anything to worry about, though.
Old Nov 6, 2008 | 05:34 PM
brodienuchies's Avatar
No...you're fine. Unless that suckers been hollowed out.
Old Nov 6, 2008 | 10:43 PM
hytek369's Avatar
i cleared with perrin hfc
Old Nov 18, 2008 | 04:02 PM
IfDontFITsPIT's Avatar
your Perrin didnt throw a CEL ?? cuz mine did
Old Nov 18, 2008 | 05:43 PM
droplet_auto's Avatar
im a inspector... as long as the obd test says catalyst ready and you have no cel your fine... not ready or n/s will make you automatically fail
Old Nov 18, 2008 | 06:28 PM
fasterthanrays's Avatar
You'll pass as long as you don't have any cels. You would have to find a way to not throw a cel. There are a few methods.
I will be doing the non fouler method.
Old Nov 18, 2008 | 07:03 PM
tephra patch has rear o2 disable... im going to test it out tomorrow and see if it passes
Old Nov 19, 2008 | 07:37 AM
FJF's Avatar
FJF
I'm in NY and I have a Works HFC - no CELs, no inspection issues.
Old Nov 19, 2008 | 07:41 AM
porsherules911's Avatar
as long as you don't have a cel light then I think your fine. My helix hfc throws a code so I'll just swap in my stock cat when I have to do inspection.
Old Nov 19, 2008 | 07:59 AM
gmore84's Avatar
Go to a autoparts store and get a 02 Fouler, I think that's how you spell it, and you put it where you 02 goes on you high flow cat and the CEL goes away everytime. Or you can buy it on ebay. A under 20 dollar fix can save you from emmissions.. I've seen it everytime.
Old Nov 20, 2008 | 09:54 AM
rear o2 disable seemed to pass... but i failed evap and egr lol
Old Nov 20, 2008 | 11:31 AM
evo4life400's Avatar
i think you will be fine. if there is no CEL than the emssions wont be a problem. if you get a hard time try to find a shop that does more performance cars. there are a few in my town that are really strict and there are others that pass you much easier.(not saying they do things illegallly). and to the guy with the evap problem..i had that too and it was some stupid plastic pipe that broke but i also have heard if the oring on the gas cap is messed up it can throw and EVAP CEL.
Old Nov 20, 2008 | 11:45 AM
kim.ry's Avatar
passed inspection with test pipe.
Old Nov 20, 2008 | 04:48 PM
ingum86's Avatar
I recently passed with a test pipe, and anti-fouler trick.
jym89709
Feb 8, 2012 05:23 AM
punker462606
Jul 7, 2007 08:39 PM
cobra2evo
Midwest Region
Mar 28, 2007 11:58 AM
my91talontsi
Jan 18, 2006 07:52 PM
inariv5573
53
Jun 19, 2004 11:33 PM
