Oil Filter Dent Issue
Old Mar 18, 2010 | 08:44 PM
tdubbz's Avatar
I just changed my oil in the EVO and I could not find a the proper size oil filter wrench for the OEM filter so I had to use one of those sh*tty universal filter wrench and I slighty dented the filter from tightening. Will this be a potential issue. (the indent is not that big)..... I'm just paranoid
Old Mar 18, 2010 | 08:45 PM
buchnerj's Avatar
I use a universal filter wrench every time and have never had a problem. How did you dent it? Over tightening? Provided it isn't too big of a dent, and there are no cracks, leaks, etc.
Old Mar 19, 2010 | 06:51 AM
tdubbz's Avatar
yeah just over-tightened. Def no cracks/leaks.
Old Mar 19, 2010 | 07:05 AM
rcheung's Avatar
Depending on how big the dent is it may or may not be an issue. Next time just hand tighten it. There is no need to use a tool to tighten the oil filter. The filter it really easy to access by hand.
Old Mar 19, 2010 | 07:07 AM
tdubbz's Avatar
Tried hand tightening first obviously but that bad boy was leaking.... Seems good now after tightening down.
Old Mar 19, 2010 | 07:39 AM
LaXGSR's Avatar
Like mentioned above, you should always hand tighten, no tools. Wearing latex gloves or a piece or sandpaper will give you more grip. Every oil filter will say hand tighten until gasket touches + X turn. Usually it's an extra 3/4 turn after the gasket makes contact. I've never had an issue hand tightening.
Old Mar 21, 2010 | 10:10 AM
92gsxbaltimore's Avatar
You shouldn't be using a wrench. Take a paper towel, spray it with degreaser, and then wipe the filter which will remove all the oil residue on it. Then you can get good grip on the filter and just tighten it as tight as you can make it with your hand.
Old Mar 21, 2010 | 12:26 PM
Evo_Jay's Avatar
+1
You shouldnt be using a wrench to tighten it, Only to remove it.
Old Mar 21, 2010 | 12:56 PM
monkey_187's Avatar
^^agreed you never us it to put it on, was this your first oil change you did yourself?
Old Mar 21, 2010 | 04:32 PM
cfdfireman1's Avatar
use a little oil on the gasket before you put the filter on then hand tighten only.
Old Mar 21, 2010 | 04:54 PM
Boost_Inspired's Avatar
next time just hand tighten the filter and u will be all good
Old Mar 22, 2010 | 10:39 AM
itr.#1446's Avatar
x2
Old Mar 23, 2010 | 06:05 AM
rcheung's Avatar
I had that happen once, it turned out the gasket from the other filter got stuck on the housing so when I screwed on the new filter, there were 2 gaskets on there, the old one and the one thats on the new oil filter. Did you check that ?
DarkSyde294
Lancer Engine Tech
Sep 24, 2013 01:40 PM
Kreeker
Sep 30, 2012 02:17 PM
asianfury01
17
Apr 27, 2008 07:43 PM
Johnny Boy
Mar 7, 2006 10:32 AM
livesports
Dec 16, 2005 05:24 PM
