tune with stock boost controller or ams manual one
Old Apr 5, 2010 | 10:45 PM
vipevo9's Avatar
im gonna get my car street tuned and i was wondering if it would be better to use the stock boost controller or a ams manual one?
Old Apr 5, 2010 | 11:52 PM
iseedipp's Avatar
uh stock boost controller?
Boost control:
Manual Boost Controllers (cheap, effective, and best of all they work with no hassle!):
-Joe P XZ
-Hallman ES
-DB Performance
-Skip the ebay ones here, they are usually sub-par.
ECU Controlled Boost:
-option #1 (warranty friendly):#65 pill ($10-30 in parts- pills available pre-drilled here)
-option #2: Wire in GM BCS (~$70 in parts due to a recent price increase)
If you go the GMBCS route pick up an evo X map sensor for ~$150 to save yourself the hassle of load-based and to just do it right the first time. Omni has also recently released a 4-bar MAP sensor that is able to be had for around $120. Use this with mrfred's direct boost control mod for optimal ecu-controlled boost.
Evo8's set PEAK boost to 21psi (untuned) or 23psi (tuned)
Evo9's set PEAK boost to 22psi (untuned) or 24psi (tuned)
Old Apr 6, 2010 | 01:15 AM
CJ2X's Avatar
There is no such thing as "stock boost controller".
Old Apr 6, 2010 | 12:37 PM
vipevo9's Avatar
the stock boost solenoid
Old Apr 6, 2010 | 12:38 PM
vipevo9's Avatar
the boost that is controlled by the ecu i meant
Old Apr 6, 2010 | 12:47 PM
Boosted Tuning's Avatar
If you'd like ECU boost, its best to go with a 3 port solenoid and not the stock one.
A MBC (manual boost control) is simple and easier for the end user, in case you need to lower the boost for some reason, add new parts n have to adjust the boost or if you just wanna raise the boost and throw some race gas in.
whotippedmycow
Jun 19, 2013 06:03 PM
sith_killer_99
Dec 29, 2009 06:01 PM
speedmaster747
Nov 2, 2009 08:11 AM
Jake26
Jun 27, 2009 05:54 AM
EV0lut10n_8
AMS flash
Nov 26, 2007 07:50 AM
