What clutch kit for 330whp daily driven EVO VIII?
Old Jul 5, 2010 | 03:39 PM
03evo8gsr's Avatar
act-hdss for that power.
Old Jul 5, 2010 | 05:43 PM
batty200's Avatar
Just use the stock clutch. I have pulled 1.6 60fts and driven over 20K miles on my mid 300whp evo. The stock clutch just works awesome. I had a twin in there and for the power level it was way overkill and super annoying on a daily driver. If you want a little more then do an ACT HD with a 6puck sprung hub disk. I have that for when I put on a t3 based turbo and move to the 500whp range.
Old Jul 5, 2010 | 06:31 PM
dvd_mi's Avatar
My stock one started slipping. I went to F1 kit (from eBay) and my wedge collar ring went off the clip twice when I was launching the car (to test the clutch). Right now I am tired of taking everything apart and I want something that will last long. Does anyone have a Competition Clutch Stage 2 ??? What do you think about it???
Old Jul 5, 2010 | 08:50 PM
riceball777's Avatar
act hdss would work great
i love this clutch on mysetup and i have no probalems with it and i DD my car i just never launch it
Old Jul 5, 2010 | 08:53 PM
white_evo27's Avatar
ACT Clutch
Old Jul 5, 2010 | 09:22 PM
BluEVOIX's Avatar
Get the stage 3. Its kevlar so it can take the heat from the launching abuse and the pedal feel very close to stock. Also engagement is pretty smooth for normal take offs and not choppy like puck style disks are.
Old Jul 5, 2010 | 09:44 PM
wreckless969's Avatar
Just get the Execy Twin HD. It holds a lot of power so if you decide to go bigger you dont have to replace the clutch.
Do it right do it once.
Old Jul 5, 2010 | 09:56 PM
biggieevoIX's Avatar
exedy stage 1 HD
Old Jul 6, 2010 | 03:03 AM
dvd_mi's Avatar
What about Competition Clutch Stage 2 ??? Does anyone have it???
Old Jul 6, 2010 | 04:49 AM
FJF's Avatar
FJF
How long did the stock clutch last you?
Old Jul 6, 2010 | 06:07 AM
mx4life85's Avatar
I'm also having a hard time picking out what Competition Clutch I need. How does one know what stage you need?
Old Jul 6, 2010 | 12:26 PM
victoryred's Avatar
Exedy twin hands down and if you ever plan to to bigger the exedy twin well hold the power.
Old Jul 6, 2010 | 02:22 PM
charlie.tunah's Avatar
my act gives me problems at the track, but fine for DD. I just dont ring it out as hard, so the issue never happens.
Old Jul 6, 2010 | 03:18 PM
lude2evo's Avatar
Originally Posted by evo unknown
Exedy Twin Plate kit (with flywheel), SS Clutch Lines, STM Clutch Fork Stop, OEM Throw out bearing and you are set. It is expensive, but well worth it.
agreed. i have the exedy twin, ss upper and lower clutch lines, underhood bushings 6spd, in cabin bushings, oem tob, and ill be switching to a full synthetic clutch fluid with the stm stop fork as well
ill chime in with results as soon as its broken in
Old Jul 6, 2010 | 03:21 PM
94AWDcoupe's Avatar
clutchmasters stage 3.
kevlar friction material. smoother than stock to drive. holds more power. lasts longer than stock friction material. shifts about like stock. stock type lockout. when disc wears out simply install new disc and you are ready to go again. kevlar doesnt wear out metal. it just polishes it. best friction material on the market.
had a car here with 2.3/35r that was using this clutch. held 520whp but I dont remember tq numbers. likely around 475ish tq.
