remove evo 8 shift boot?
Old Jan 10, 2011 | 12:57 PM
JoNaH's Avatar
i been searching for a while now, i know in my evo MR i just unclip the top of the boot, remove the ash tray, pull that gray panel off then unscrew the boot from the bottom,
now on a evo 8? same thing? how do i take the boot off since it has no clip like the evo mr does (the button clip that is on the bottom of the shift knob). I really dont want to remove the entire console.
thanks
Old Jan 10, 2011 | 02:20 PM
JoNaH's Avatar
no one?
Old Jan 10, 2011 | 04:19 PM
JoNaH's Avatar
bump!!!!!!!!!!
Old Jan 10, 2011 | 04:21 PM
dac001's Avatar
think you have to remove the entire console
Old Jan 10, 2011 | 04:23 PM
JoNaH's Avatar
u sure? because that gray piece i think should come off? anyone else with a definate answer? thanks
Old Jan 10, 2011 | 04:55 PM
JoNaH's Avatar
bump, there has to be one person on this forum that knows how to take this thing off
Old Jan 11, 2011 | 07:26 PM
JoNaH's Avatar
bump
Old Jan 11, 2011 | 09:01 PM
JoNaH's Avatar
anyone?????? 64 views and only 1 person to help
Old Jan 12, 2011 | 12:46 AM
ixmrgg's Avatar
any of these help?
https://www.evolutionm.net/forums/ev...shiftboot.html
https://www.evolutionm.net/forums/ev...hift-boot.html
https://www.evolutionm.net/forums/04...hift-boot.html
http://www.redlinegoods.com/LancerOZ0203install.shtm
Old Jan 12, 2011 | 08:58 AM
JoNaH's Avatar
you are amazing, thanks
Old Jan 12, 2011 | 03:01 PM
BoostedFury's Avatar
I was just about to search for this, thanks.
Old Feb 13, 2011 | 12:12 PM
Dragking2189's Avatar
To remove the shift boot you have to unscrew the shift knob one you've done that remove the trim plate which is the gray piece that holds the cigarette lighter and the ash tray, get a flathead and put it on the side and lift up the gray piece after, you will notice that the cigarette lighter is attached by some cables unplug the cables and you should able to take off the gray piece carefully . Once the gray piece is off , flip it over you will see 4 screws , get a a screwdriver and unscrew every single one . The shift boot should come right off the trim plate .
Cyrax91
Nov 21, 2016 07:20 AM
ekizenbe
Dec 31, 2013 01:50 PM
Purevol8
Feb 27, 2012 09:14 PM
ryan78
10
Apr 10, 2011 12:30 AM
PDXEvo
Evo X How Tos / Installations
29
Feb 1, 2010 02:57 PM
