Engine Oil
Old Nov 30, 2012 | 03:41 PM
fsc0224's Avatar
Engine Oil
Recently when I started my car from real cold weather, there were a lot of white smoke out of my exhaust. I wanna know whether it is normal or not. And when I speed up from second gear, there was a little bit black smoke came out. Are these phenomenon is normal? One of my friend told me my car should be retuned. However, I saw few evos does the same thing when they speed up or shift.
Old Nov 30, 2012 | 03:50 PM
Teal2nnr's Avatar
Well dark black smoke is unburn fuel...usually. But if this is something that has just started happening then something is a miss....unless of course you're just noticing this. Has the car ever been tuned?? what AFR's are you running at WOT?
Old Nov 30, 2012 | 03:52 PM
Cal City Evo's Avatar
Really?
If your car is cold that is condensation or water vapor from the cold exhaust getting warm..
As for the black smoke it goes rich when you mash the gas pedal. Lots of fuel being burned equals black smoke or in your case a trace of it anyhow.
Nothing to be concerned about.
Last of all what does this have to do with oil????
Old Nov 30, 2012 | 04:13 PM
jeremy52048's Avatar
yeah its probably condensation, i get nervous when i see that too lol. on cold mornings
Old Nov 30, 2012 | 04:26 PM
Drew1's Avatar
Way too little info for anyone to really say anything. But from just reading what you gave, pretty normal.
Any modifications etc would tell a lot. Burning any oil between changes as well...
Old Dec 1, 2012 | 07:07 PM
post a vid of it.
Old Dec 2, 2012 | 05:03 PM
Jag14916's Avatar
Where im at it ranges from 30-55 degrees fahrenheit this time of year. When I start my car every morning I get white smoke till its all the way at temp. Im pretty certain its not actually smoke, more vapor from condensation on your pipes i.e. your breath in the cold air lol. Also if i dont give my car a good rip every drive or so, when mash the gas it will put out a little puff of black smoke. If that happens all the time you may have a issue, otherwise I think your fine.
Old Dec 3, 2012 | 08:55 AM
thepoint4life23's Avatar
What he said ^
Old Dec 3, 2012 | 09:04 AM
misterevo8's Avatar
^2nd that. happens to me too.
Old Dec 3, 2012 | 09:54 AM
heel2toe's Avatar
Correct, the white smoke is just condensation and its completely normal. My car does the same thing, but only in the cold. Another interesting note related to condensation; I have a vented oil catch can and during this time of year, it collects a bunch of condensation. I emptied it last night and it basically filled up an entire water bottle. Typically, itll only catch a little oil along with some unburned ethanol.
Old Dec 3, 2012 | 11:04 AM
whiteEvo08Y's Avatar
I have the same smoke coming out of my car in the morning. Its normal and don't worry about it. But as for the black smoke, i don't get that. Maybe like the other members said you are running rich and might need a tune.
Womb Raider
12
Jan 13, 2017 05:15 PM
Hoojan
Jul 21, 2016 08:36 AM
Grip Master
Apr 6, 2009 01:51 PM
06FQ360
Jan 5, 2008 01:45 PM
maxum17ft
Lancer Troubleshooting
22
May 26, 2005 02:31 PM
