Newbie: Front Strut Won't Line Up
Old Dec 25, 2012, 09:41 AM
kj1976's Avatar
I have a 2001 Mitsubishi Mirage 1.8 and I am replacing the front-struts. Taking the front right strut off took no more than 30 minutes.
*Tools: Socket wrench with a 17mm for the lower bolts and a 15mm for the top bolts under the hood.
*Spring Compressor Tool used to remove the old strut and add the new one.
*Jack Stands - Lifted both sides up for removal
Once everything was put together I attached the strut back in the correct position and I noticed that the strut holes did not match up where they should be.
My question too you great mechanics, as a newbie what should I do to get the strut to match up so I can add the bolt and screws back?
Checking other responses stated that I should put a screwdriver in the hole to match it up. The problem there is that the way it is angled, I can't put a screwdriver in the hole. Any thoughts on the issue?
Photos attached..
Attached Thumbnails Newbie: Front Strut Won't Line Up-strut.jpg
Old Jun 1, 2015, 01:44 PM
DannyG90's Avatar
Has anyone figured this out yet?? I'm having the same problem right now
Old Jun 1, 2015, 02:08 PM
.M.
.M.'s Avatar
Use some wd40... or whatever you prefer. Try a hammer. Maybe a breaker bar. Have a friend help. Push up/down on the hub. It'll line up. Just keep at it.
marksae
61
Aug 13, 2017 12:30 PM
alexc
Dec 9, 2015 01:08 AM
djdnav
Aug 23, 2014 07:22 PM
jack1526
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jul 11, 2011 07:48 PM
Blacksheepdj
35
Jun 18, 2011 12:17 AM
Quick Reply: Newbie: Front Strut Won't Line Up
