ExtremeTurboSystems.com – WA Custom Intercoolers, Intercooler Kits, Turbo Kits and Performance Parts. [Visit Site]
ETS Corn Lovers Sex.(SC61 on E85)
Old Aug 2, 2008 | 08:14 AM
[EVO]Cookie's Avatar
Originally Posted by dsmfan95
Would a Hobbs switch be considered a toggle switch? That's what I run on my twin pump setup.
Toggle switch hot wired to the battery just like you would put in a race car. With the A1000 size pump you only need one. I didn't know if anyone was running one on the stock relay setup. I don't want to use a twin pump setup I only need an extra 100lph to be safe.
Old Sep 1, 2008 | 12:29 PM
Update
I did some logging and wanted to update this. This is E85 with a MAFT and logging 2 byte at just 25psi of boost.
309 load @ 7K
330 calculated load
93% IDC @ 7K RC1000 scaled at 750 53psi base fuel pressure
2440 2 byte Air flow @ 25psi
I hope I can get the IDC's down with 1200's 93% is too high. If your looking at a SC61 or the HTA35R's and plan on running E85 you might want to buy 1200cc injectors as a minimum.
Old Sep 1, 2008 | 01:28 PM
Turbo Kyle's Avatar
You still got 10 more psi to go for that turbo to "Wake up" LOL
Old Sep 1, 2008 | 06:01 PM
Boltz.'s Avatar
FCOTM Winner
93% on evoscan is still safe. From everything I've ever seen it reads about 10% low.
Old Sep 2, 2008 | 01:31 PM
Yea I've seen Evoscan have some far fetched log's before I was hopping it was reading high rather than lower. Even at 80% at 25psi I don't have any safety margin. I would like to see 80% @ 35psi the car is just stupid fast at 30psi.
FameEvo
31
Jan 22, 2015 09:24 AM
fortyPSIrs
Sep 28, 2011 04:30 AM
Pizzamangtr
Oct 16, 2009 09:29 AM
dsm25psi
15
Jan 2, 2008 03:20 PM
nikkadanny
45
Dec 27, 2007 05:33 AM
