Evo 9 + ETS PT6262 turbo kit
Bryan,
Alittle off topic but whats the most you have seen as far as airflow out of a stock turbo??
my car is the one pete tuned. the supporting mods to the e.t.s 6262 unequal length manifold kit are as followed
buschur intake
aps twin vent bov
3" test pipe with magna flow 3" cat back
comp 272 cams
ams intercooler with upper pipe
880 injectors
as pete stated this trubo would perform much better with race gas. it wants boost for sure. i ran at the shoot out in englishtown today but pete is still working out the kinks on the two step. still kinda trying to find the sweet spot of where this turbo likes to be. on pump gas 25 to 26 psi seems to be best. this car has 81,000 miles on it and has seen boost daily for years.
buschur intake
aps twin vent bov
comp 272 cams
880 injectors
I'm pretty sure the unequal length short runner spools faster than an equal length but the equal length makes more top-end.
well the spool actually isnt to bad. im not sure what it is compared to as far as the equal length but im at full spool by 4800 rpms. im launching at 6500 right now but the load and boost is what helps the car come off the line. see pete im learning something from you lol. pete can chime in but he is still working on the perfect consistent combo. he is very close though.
No I am talking about the trans.
Make sure you are both talking about the same gear when comparing spool.
If yours spools at 4800 in 3rd, then compare his in 3rd as well.
You can't compare your 3rd and his 4th. The turbo will spool quicker the higher the gear.
