Evo X Drivetrain
Old Sep 26, 2007 | 09:54 AM
BBYBruno's Avatar
Originally Posted by BLUE EVO702
So 2003-04 are 3rd wheel drive and 05-06 is awd!?.
So what you can do is sue Mitsu for false advertising on the 03'-04' Evos and make millions. That's what i'm doing.
Old Sep 26, 2007 | 11:58 AM
evilution310's Avatar
nice job with the 3wd 50% of the power goes to the rear and 50% goes to the right front tire and the other one is just along fot the ride.
Old Sep 26, 2007 | 12:29 PM
WheelGap's Avatar
The Evo has a helical front LSD, which isn't technically a limited slip diff at all. It's similar to a Torsen, and here's a good explanation of it:
The Quaife differential works on an entirely different principal. Each axle is attached to a gear, called the sun gear, and each sun gear has several small gears around it called planet gears. The planet gears from one side mesh with the planet gears from the other side, so when you put both drive wheels in the air and turn the left wheel clockwise, the left planet gears turn counterclockwise. They turn the right planet gears clockwise, which turn the right wheel counterclockwise. In other words, the wheels spin in opposite directions just like a normal open differential.
The magic comes from all the gears having their teeth cut helically. That means the teeth are angled so that if the gear were long like a log, the gears would spiral around the log in a helix. When you put a big load on a pair of helically cut gears, there's a reaction force pushing them sideways.
Look directly at the interface between two gear teeth and the reason for this sideways force is pretty obvious. The gear teeth meet at an angle, and when you try to push straight through an angled interface like that, you get shoved sideways. The latch on the front door of your house works the same way. Close the door until the latch touches the striker plate and you have a similarly angled interface. Push straight on the door, and the sideways reaction force pushes the latch into the door. In a helical differential like the Quaife, the reaction force shoves the sun and planet gears sideways, where they rub against the ends of their housings. This rubbing encourages both wheels to turn together.
The reaction force only happens if there's some resistance to your shove, though. If there was no resistance in our door latch example, the doorframe would just fall over. If there's no resistance from the other gear, it will just turn. This is why, technically, a helical limited slip isn't really a limited slip. Put one wheel on ice and the other on pavement, and there won't be enough resistance to prevent all the power from going to the ice.
So all Evos from the factory are 3WD by the nomenclature used in this thread.
Old Sep 26, 2007 | 01:49 PM
Jadiem's Avatar
The American 2003 and 2004 GSRs are without the helical limited-slip front differential and 6-speed manual transmission. The 2004 US spec RS models, however, do have a front helical limited-slip differential. All 2003, 2004 and 2005 RS and GSR models have the Japanese Evolution VII's 5-speed transmission. The MR edition was introduced to the US in 2005, with ACD and the only model with a 6-speed transmission. The 2005 US spec RS and GSR have the ACD standard, and the front helical limited-slip differential is now standard on all models. The timing and tuning are also slightly lower than its Japanese counterpart, allowing it to adhere to the strict emissions regulations of the United States.
taken from http://en.wikipedia.org/wiki/Mitsubi...Evolution_VIII
sandmantt
Dec 28, 2015 12:25 PM
Gazika
Sep 30, 2009 11:44 AM
S1MPSONS
28
Feb 6, 2006 12:11 PM
sir lurks alot
Feb 19, 2004 04:15 PM
arpad
27
Nov 13, 2003 12:49 AM
