Here's the MOTOR TREND article (56k beware)
Old Sep 2, 2004 | 11:04 AM
EVO8HKS's Avatar
thanks for posting, time to go pick on my "subaru rules" best friend.
Old Sep 2, 2004 | 11:14 AM
mitsuorder's Avatar
This makes me wonder if a sort of launch control could be implemented in a reflash. Maybe once the MR's come out people could look at the code controlling the clutch-in rev limiter and use it to come up with a stock ecu launch control that can be used in other no '05 evos.
Old Sep 2, 2004 | 11:19 AM
1NastyEvo's Avatar
Sweet! Thanks alot man.
Old Sep 2, 2004 | 11:23 AM
Tanner_Hall's Avatar
the MT reviewer definitely seems to prefer the Sti, though he grudgingly declared the MR the winner.
Old Sep 2, 2004 | 11:25 AM
EVO Neil's Avatar
Originally Posted by 1QWKEVO
1.11g's !!!! wow man the slalom speed should have been faster with that kind of grip... Something doesn't add up
Uh yeah, explain to me what your thought process is on this...
Now I suppose you want to see the video to prove Motor Trend ran the cars...
Some people are never satisfied! Jeez!
Old Sep 2, 2004 | 11:27 AM
EVO Neil's Avatar
It's not just the MR that gets the 5,000 rpm launch limit, it is all versions of the Evo, world-wide.
Old Sep 2, 2004 | 11:29 AM
GPTourer's Avatar
Neil, what was the suprise you mentioned that would be part of the article?
Old Sep 2, 2004 | 11:31 AM
mitsuorder's Avatar
I understood that, just mistyped, maybe someone apply that rev limit/launch control to the '04 and '03 models ecu's. Time will tell, but this was doable with the dsm ecu's from what I've heard from some dsm buddies.
edit: meant to say I assumed that all 05's would have this
Old Sep 2, 2004 | 11:36 AM
bolsen's Avatar
built in launch control lol!!!
Old Sep 2, 2004 | 11:39 AM
EVO Neil's Avatar
The surprise is the next story about the European versions, the Mitsubishi Lancer Evo MR FQ340 versus the Subaru WRS STi WR1. Maybe that will move some of you to support my salary and buy a copy instead of having someone post the article on the website which certainly takes away from that...
Old Sep 2, 2004 | 11:40 AM
travestyevo's Avatar
Umm... Unplug the clutch switch.
Done.
Old Sep 2, 2004 | 11:41 AM
EVO Neil's Avatar
That's what we thought until we tried to launch the car. 5,000 rpm is just too low. You end up slipping the clutch more, but then again the transfer case doesn't take the power surge hit.
Old Sep 2, 2004 | 11:43 AM
mitsuorder's Avatar
I feel so bad for these poor test cars and whoever eventually ends up with them lol
Old Sep 2, 2004 | 11:45 AM
DocMortal's Avatar
5000 rpm launch control sucks... Then again I bet a reflash could either bump it up or eliminate it....
FOr sure they designed this also to void most warranty,it would be easy to check if the limiter was removed glad I got my 2003
Old Sep 2, 2004 | 11:46 AM
DizzyTT's Avatar
Evo Neil, I am going to buy it, so you can have your ramen noodles for dinner!
