Intakes, Inductions Boxes, Maf Pipes... OH MY!!
Old Jan 10, 2005 | 10:18 AM
ArchieBabes's Avatar
I have the HKS RS Kit and I have to add 12 - 15 of fuel on 3k - 4k just to maintain the afr to below 11
I made 310whp on a dynojet with a mild 10:2 AFR by redline on 91 pump gas
Old Jan 10, 2005 | 10:21 AM
Old Jan 10, 2005 | 10:51 AM
MalibuJack's Avatar
Originally Posted by marksae
Oh okay.. I think I remember you mentioning that to me before. Which intake pipes did you see this behavior with? I would think the constant diameter intake pipes would slow the intake air velocity down a lot more compared to a tapering pipe that's shaped similar to the stock intake snorkel.
Hmmm.. since I don't have a UTEC, I'm gonna get an OBDII logger and log MAF readings before and after my intake pipe install. I just want to see if there are any alarming differences. If there is, I'll probably just put the stocker back on.
Yeah you'll see the airflow measured differently, not as a MAF frequency but as an air mass calculation.. but it'll be a dead giveway for you..
The only intakes that do not have any anomolous problems are the ones that do not alter the diameter of the intake, all aftermarket intakes, whether their straight pipe, or tapered, all alter the air velocity from stock. by about 6-10% or more.. the advantage of the HKS is its less prone to stalling with a Recirc BOV because of the taper (it decelerates reversed airflow because it tapers larger) However its also prone to lean conditions.
You guys have to understand that 100% of the gains in an aftermarket intake and MAF pipe are caused by a lean condition (lowered maf reading across the board), since the intake of the turbo is STILL just under 2.5" and the stock tube is 2.5" and the stock MAF is 3" the restriction you will experience before anything is the inlet on the turbo.. The stock airbox, and other components will flow as much air as the stock turbo could EVER demand.. Its designed that way.. Most power gains using the stock turbo are improved efficiency or higher velocity airflow, not necessarily more volume.
Old Jan 10, 2005 | 11:10 AM
GokuSSj4's Avatar
i have notice that with the UICP from BR w/ 1g BOV and his intake MAF pipe (new MAF pipe by BR) and filter the car runs a bit lean (nothing to drastic) since it sees at WOT near 11.5-11.8. Before it was at 11.2-11.5 , this is on 91 octane, changes are not dramatic as i read in the pass threads with upgraded intakes. The car will be tune again with upgrade injectors and pump.
Old Jan 10, 2005 | 11:47 AM
marksae's Avatar
Good info MalibuJack!
Old Jan 10, 2005 | 02:04 PM
TampaTurbo's Avatar
Originally Posted by ArchieBabes
When is the UTEC gonna have the non MAF for our cars like the AEM one with the MAP conversion.
I think this should fix the fluctuating MAF readings and anomoly changes...
Good question. Please help!!!!
Old Jan 12, 2005 | 04:08 PM
Eclipsed Evo's Avatar
Originally Posted by Imprezd
Recently I have been able to tune a few different EVO8 with supposed “Stage II” Mods. The intakes that have been tested were the ARC Induction Box, HKS, RMR and Injen. All of these systems make the car run ridiculously lean under boost. It wasn’t common to see 13.1 afr at 20 psi of boost at 3500 rpm. The last customer I had come in made 210whp on another shops dyno because of this lean condition. Once he was tuned he made his normal 285 whp for the Stage II like modification. The end result was a happy customer and car than ran a lot better than when he arrived.
Jermaine~
www.turboxs.com
301-977-4727
That customer was me. Just wanted to say thanks for doing a great job. My car runs like a dream now and has a good bit more ***. Just bought some HKS 272 cams, ARP head studs, AEM cam gears, and crower springs. I'll be taking it back to Jermaine soon as they get installed. Thanks again and I'll see ya in a week or two.
Old Jan 26, 2005 | 06:55 PM
SMrider102's Avatar
i have just a cone style filter and the stock intake pipe, would this cause a lean condition also?
Old Jan 26, 2005 | 07:03 PM
MalibuJack's Avatar
It could.. I noticed the cone filter I had did cause the car to run a little leaner with no other modifications.
Old Jan 27, 2005 | 07:13 PM
SMrider102's Avatar
thanks for the info MalibuJack
Old Jan 27, 2005 | 07:27 PM
kapolani's Avatar
This thread has been very informative.
I've finally bit the bullet and decided to go with the Utec. This is my first attempt at "tuning" my own vehicle - so I like to absorb as much info as possible. I can't help it - I like tinkering with stuff - it's my curse (by the way - is there any recommended reading on the subject?)
Would you say it's worth the 'trouble' to go with an aftermarket intake rather than opening the exhaust side of the equation?
Is it worth the effort to even use an AI or just keep the stock unit?
Thanks...
Old Jan 27, 2005 | 09:31 PM
bbbwrx's Avatar
What have you noticed with the TurboXS intake? Same type of stuff. I am guessing that it is going to be hard to be subjective on your own pieces but it would be nice to know.
Ben
Old Jan 28, 2005 | 11:30 AM
Imprezd's Avatar
Our intake may cause a slight difference in AFR, but not as much as we have been seeing with these others. We do not alter the intake pipe after the maf, anything that changes the nature of the vortices in the intake tract will affect maf readings and afr.
Thanks,
Jermaine~
DTM
72
Sep 7, 2008 02:00 PM
PERRIN_Jeff
20
Jul 31, 2008 09:15 AM
PERRIN_Jeff
67
Jun 25, 2008 08:33 PM
nj1266
Feb 11, 2007 05:29 PM
