Hks V-pro
Old Nov 22, 2008 | 12:57 PM
  #61
scorke's Avatar
Anybody here using the AFK?
Anybody here install theirs themself?
Scorke
Old Nov 24, 2008 | 09:47 AM
  #62
kcevo's Avatar
Scorke
I'm using the older model unit if that helps at all.
Old Nov 24, 2008 | 09:50 AM
  #63
scorke's Avatar
Older AFK?
Which one, which unit, what does the display for the one your using look like?
Appreciate it
Scorke
Old Nov 24, 2008 | 09:57 AM
  #64
kcevo's Avatar
Older AFK?
Appreciate it
Scorke
The older unit was called the Knock Amp. It is silver with a silver display like an EVC 5. These units did not come with a wideband sensor either, and the sensor is a NTK sensor instead of the Bosch LSU sensor that came with your AFK.
Old Nov 24, 2008 | 10:00 AM
  #65
scorke's Avatar
I do not have an AFK yet and am having trouble deciding between picking up an older one and getting a new A/F sensor or shelling out 800 for a new setup.
What are you're thoughts/opinions, very much appreciated.
Scorke
Old Nov 24, 2008 | 10:11 AM
  #66
kcevo's Avatar
Scorke
Personally, I would pick up the newer one as the replacement sensors are much cheaper for a Bosch LSU vs. the NTK sesnor. Also, setting up the knock sensor to be read to the ecu for the AFK is much easier than the older models by far.
Old Nov 24, 2008 | 10:12 AM
  #67
scorke's Avatar
Thats what I had been told, thanks Chad.
Scorke
Old Jul 27, 2009 | 10:11 AM
  #68
coastevo's Avatar
How hard is it to learn the software if you were able to get it somehow.. any opinions?
