Best Cam Gear settings for 272s?
Old Jul 18, 2005 | 09:24 AM
lbcevo's Avatar
My tuner set my gears at (I) -5, (E) -1.5. I seem to be 10-15 WHP low on power. Is this a good setting for the gears or could new settings increase power? I'm in CA running 91 octane.
My mods: Utec, TBE w/CD, HKS 272s, Walbro, and MBC set at 22-24 psi depending on octane.
Old Jul 18, 2005 | 09:26 AM
lexat20's Avatar
There is a recent post on which cams to buy. Ludikraut says -4 -1 for no idle issue without sacrafice on power
Old Jul 18, 2005 | 10:35 AM
BJai02's Avatar
Most people do either -4/-1, -3/-3, or -2/-2
Old Jul 19, 2005 | 11:56 PM
Aby@MIL.SPEC's Avatar
https://www.evolutionm.net/forums/sh...3&page=3&pp=15
page 3, post ~35 has a -3/-3 vs -4/-1 power curve compare.
Old Jul 20, 2005 | 06:06 AM
HiHeatEVO's Avatar
-4/-1 here with perfect idle...i am on powerfc(the one that uses maf)
from the thread i read in the past -4/-1 gives more topend power it's like 5-8hp but at -3/-3 it gives more low and mid-grunt i think through the low to low mid it's like 10 more hp. depends on your driving habits...supposedly gives a nice cam lope. silversurfer i think roadraced on each setting and found -4/-1 gave him better lap times.
enjoy those cams
Old Jul 20, 2005 | 08:04 AM
MalibuJack's Avatar
The powerFC that uses MAF has a low airflow MAF limit feature doesnt it? (clamps the signal at a stable number at idle?)
I've been so lax on getting cams in my car.. I've tested a set of custom grinds that I wasn't happy with, now I have stock cams and will go to 280's.. I never had a chance to test 272's to give you guys an idea of what will work well.
Old Jul 20, 2005 | 10:07 PM
BJai02's Avatar
280? I haven't seen any good results with them running on stock turbo. So you are upgrading to a bigger turbo soon? If not, stay with 272's and do more experiment on the cam timing setting... then give us feedback on your research liek what you usually do
Old Jul 20, 2005 | 10:12 PM
MalibuJack's Avatar
I have a specific reason for running 280's, but its not due to a bigger turbo, well, its bigger, but still a twin scroll stockish.. But I have plans for alot of head work and a stroker engine. I liked the 272's but my gut is telling me the 280's need more research..
Old Jul 21, 2005 | 05:33 AM
HiHeatEVO's Avatar
i thought curt brown had 280's in his stock turbo race car.
Old Jul 27, 2005 | 04:30 PM
LuxuryBroker's Avatar
any sugestions for the piper ralley cams settings ??
Old Jul 27, 2005 | 07:22 PM
MalibuJack's Avatar
I was actually under the same impression.. He does tell you if you ask, so if your curious about it, just message him.
TwistedEvo8
26
Aug 7, 2016 06:48 PM
razorlab
25
Dec 5, 2005 01:53 PM
Smogrunner
Automotosports - Illinois
Sep 19, 2005 01:02 PM
titaniumkingpin
11
Nov 29, 2004 01:43 AM
