Engine Overboost...getting pissed!!!
Originally Posted by Nez136
So even with a CEL on i won't loose HP?
If you want the car to pass an OBD-II inspection, turn the boost down to 16psi or less, use the passthrough or map1 with a very lame map with ECU Passthrough timing and drive it for a day before the inspection..
cell's like overboost, fuel trim lean (thats an open loop issue not closed loop), O2 sensor rich/lean or slow.. etc.. just ignore them for the most part and reset the ECU.. you "could" get a reflash to alter the MAF curve and ignore the boost cut settings, but your much better off not doing it.
PearlWhiteX
May 9, 2016 08:05 PM
twinspoolin94
Oct 15, 2015 05:28 AM
TS Dork
Nov 28, 2013 07:34 PM
