Another set of logs, opinions wanted.
Old Oct 2, 2005 | 06:24 AM
WarmPepsi's Avatar
Code:
  RPM   PSI  MAF TPS Load Knock   AFR   Inj   Ign   Fuel Boost   MAF
 3853,+26.6, 721, 44, 10,   00,  11.8,  30.8,+12.8, +0.0,ECU.  , 788
 4273,+26.6, 959, 49, 10,   00,  11.8,  41.3,+13.1, +0.0,ECU.  ,1077
 4616,+26.6,1282, 50, 20,   00,  11.3,  60.0,+10.5, +0.0,ECU.  ,1497
 5128,+27.0,1412, 49, 40,   00,  10.7,  65.0, +7.9, +0.0,ECU.  ,1388
 5592,+26.8,1618, 59, 60,   00,  11.6,  73.7,+10.0, +0.0,ECU.  ,1543
 6127,+26.8,1694, 99, 70,   00,  11.6,  79.5,+12.9, +0.0,ECU.  ,1612
 6666,+26.8,1742,100, 80,   00,  11.6,  82.6,+15.7, +0.0,ECU.  ,1851
 7032,+26.6,1798,100, 90,   00,  11.4,  82.8,+16.4, +0.0,ECU.  ,1748
 7473,+26.3,1824,100,100,   00,  11.4,  82.6,+17.3, +0.0,ECU.  ,1773
 7627,+26.1,1818,100,100,   00,  15.5,  84.1,+18.0, +0.0,ECU.  ,1689
 7390,+25.9, 406,  3, 00,   00,  19.1,  15.6,ECU. , +0.0,ECU.  , 182
 6734,+25.9, 157,  0, 00,   00,  13.4,  11.9,ECU. , +0.0,ECU.  , 617
 5611,+26.1,1253,100, 40,   00,  14.5,  57.3, +8.2, +0.0,ECU.  ,1381
 5659,+26.3,1655,100, 30,   00,  10.6,  76.8,+11.0, +0.0,ECU.  ,1748
 5717,+26.3,1618,100, 40,   00,  11.0,  74.7,+11.7, +0.0,ECU.  ,1572
 5910,+26.3,1602,100, 70,   00,  11.8,  74.5,+11.8, -0.6,ECU.  ,1592
 6184,+26.3,1650,100, 80,   00,  11.7,  78.3,+13.1, +0.0,ECU.  ,1724
 6459,+26.1,1736,100, 90,   00,  11.7,  80.5,+14.7, +0.0,ECU.  ,1736
 6666,+26.1,1742,100, 90,   00,  11.4,  81.2,+15.7, +0.0,ECU.  ,1712
 6915,+26.1,1754,100,100,   00,  11.5,  83.6,+15.9, +0.0,ECU.  ,1785
 7092,+25.9,1766,100,100,   00,  11.6,  84.6,+16.4, +0.0,ECU.  ,1785
 7293,+25.9,1785,100,100,   00,  11.5,  84.0,+17.1, +0.0,ECU.  ,1748
 7507,+26.1,1792,100,100,   00,  11.5,  84.6,+17.3, +0.0,ECU.  ,1760
 7575,+26.1,1831,100,100,   00,  12.3,  84.9,+17.7, +0.0,ECU.  ,1748
 7662,+26.3, 351, 10, 00,   00,  12.3,  11.7,ECU. , +0.0,ECU.  ,1231
 7107,+26.3, 404,  0, 00,   00,  13.6,  15.8,ECU. , +0.0,ECU.  , 471
 5973,+26.3,1381,100, 40,   00,  14.0,  64.9,+11.7, +0.0,ECU.  ,1373
 5952,+26.6,1742,100, 30,   00,  10.5,  81.8,+12.1, +0.0,ECU.  ,1736
 5984,+26.3,1644,100, 50,   00,  10.6,  76.3,+12.2, +0.0,ECU.  ,1524
 6116,+26.6,1618,100, 80,   00,  11.8,  75.2,+12.5, +0.0,ECU.  ,1445
 6218,+26.6,1612,100, 90,   00,  11.6,  77.2,+12.5, +0.0,ECU.  ,1644
 6349,+26.6,1694,100, 90,   00,  11.6,  79.2,+13.7, +0.0,ECU.  ,1592
 6459,+26.6,1700,100, 90,   00,  11.6,  79.9,+15.0, +0.0,ECU.  ,1633
 6600,+26.1,1706,100, 90,   00,  11.6,  81.4,+15.5, +0.0,ECU.  ,1700
 6693,+26.1,1748,100, 90,   00,  11.4,  81.2,+15.7, +0.0,ECU.  ,1724
 6830,+26.3,1748,100,100,   00,  11.5,  82.9,+15.8, +0.0,ECU.  ,1811
 6958,+26.3,1748,100,100,   00,  11.4,  84.1,+15.9, +0.0,ECU.  ,1724
 7047,+26.3,1766,100,100,   00,  11.2,  85.7,+16.2, +0.0,ECU.  ,1724
 7153,+26.1,1754,100,100,   00,  11.1,  86.1,+16.6, +0.0,ECU.  ,1838
 7230,+26.1,1754,100,100,   00,  11.3,  86.4,+17.1, +0.0,ECU.  ,1798
 7358,+25.9,1754,100,100,   00,  11.3,  85.7,+17.1, +0.0,ECU.  ,1612
 7473,+25.9,1785,100,100,   00,  11.1,  86.8,+17.2, +0.0,ECU.  ,1712
 7558,+26.3,1773,100,100,   00,  11.1,  87.5,+17.5, +0.0,ECU.  ,1824
 7524,+26.6,1724,100,100,   00,  14.5,  85.7,+17.6, +0.0,ECU.  ,1677
 7342,+26.1, 167,  4, 00,   00,  13.9,  12.6,ECU. , +0.0,ECU.  ,  88
 6653,+26.1, 164,  0, 00,   00,  13.3,  22.2,ECU. , +0.0,ECU.  , 859
 5668,+25.9,1351,100, 40,   00,  14.5,  65.4,+11.7, +0.0,ECU.  ,1479
 5910,+25.7,1706,100, 40,   00,  14.5,  80.0,+12.2, +0.0,ECU.  ,1666
 6049,+26.1,1612,100, 50,   00,  11.4,  76.0,+12.4, +0.0,ECU.  ,1677
 6038,+26.1,1572,100, 80,   00,  11.4,  74.2,+12.0, +0.0,ECU.  ,1633
 6116,+26.3,1572,100, 90,   00,  11.5,  74.4,+11.4, +0.0,ECU.  ,1524
 6172,+26.3,1644,100, 90,   00,  11.5,  76.5,+12.2, +0.0,ECU.  ,1582
 6301,+26.3,1623,100, 90,   00,  11.5,  76.9,+12.9, +0.0,ECU.  ,1760
 6361,+26.3,1644,100, 90,   00,  11.2,  79.9,+13.2, +0.0,ECU.  ,1623
 6361,+26.1,1639,100, 90,   00,  11.1,  79.8,+13.7, +0.0,ECU.  ,1785
 6459,+26.3,1694,100, 90,   00,  11.2,  80.9,+14.7, +0.0,ECU.  ,1736
 6523,+26.3,1677,100, 90,   00,  11.2,  81.6,+15.3, +0.0,ECU.  ,1552
 6561,+26.3,1694,100, 90,   00,  11.2,  82.7,+15.4, +0.0,ECU.  ,1644
 6600,+26.3,1718,100, 90,   00,  11.2,  83.4,+15.5, +0.0,ECU.  ,1748
 6720,+26.3,1700,100, 90,   00,  11.1,  83.5,+15.7, +0.0,ECU.  ,1700
 6761,+26.3,1730,100,100,   00,  11.1,  83.3,+15.7, +0.0,ECU.  ,1773
 6816,+26.3,1748,100,100,   00,  11.2,  85.0,+15.7, +0.0,ECU.  ,1785
 6844,+26.6,1748,100,100,   00,  11.2,  85.5,+15.8, +0.0,ECU.  ,1666
 6930,+26.6,1754,100,100,   00,  11.2,  84.8,+15.9, +0.0,ECU.  ,1689
 6958,+26.6,1748,100,100,   00,  11.1,  84.8,+15.9, +0.0,ECU.  ,1724
 7017,+26.3,1748,100,100,   00,  11.1,  85.6,+16.0, +0.0,ECU.  ,1655
 7092,+26.3,1760,100,100,   00,  11.2,  84.9,+16.3, +0.0,ECU.  ,1677
 7122,+26.1,1760,100,100,   00,  11.1,  85.1,+16.5, +0.0,ECU.  ,1760
 7168,+25.9,1724,100,100,   00,  11.1,  84.5,+16.6, +0.0,ECU.  ,1736
 7246,+26.1,1724,100,100,   00,  11.1,  85.4,+16.9, +0.0,ECU.  ,1798
 7278,+26.1,1742,100,100,   00,  11.0,  85.6,+17.1, +0.0,ECU.  ,1748
 7326,+26.1,1760,100,100,   00,  11.1,  85.8,+17.1, +0.0,ECU.  ,1736
 7358,+26.1,1785,100,100,   00,  11.1,  86.3,+17.1, +0.0,ECU.  ,1838
 7440,+26.1,1748,100,100,   00,  11.0,  84.8,+17.2, +0.0,ECU.  ,1798
 7457,+26.1,1766,100,100,   00,  11.0,  87.0,+17.2, +0.0,ECU.  ,1700
 7507,+26.1,1785,100,100,   00,  11.1,  86.5,+17.2, +0.0,ECU.  ,1736
 7558,+26.3,1779,100,100,   00,  11.0,  87.0,+17.4, +0.0,ECU.  ,1824
thats a 1-4 run (6spd). Wondering which gear you guys are tuning for, as 4th gets quite a bit richer, and it's a little harder to tune (speeds).
No timing adjustments, still basically running the stock map, was just starting to flatten out the fuel curve, but then after seeing the 4th gear richness, i came back to regroup.
Code:
 2670,+26.6, 397,100, 10,   00,  12.9,  16.0,+14.8, +0.0,ECU.  , 493
 2745,+26.8, 436,100, 10,   00,  12.8,  18.2,+14.8, +0.0,ECU.  , 538
 2803,+26.6, 466,100, 10,   00,  12.7,  20.5,+14.6, +0.0,ECU.  , 388
 2896,+26.8, 550,100, 10,   00,  12.1,  22.9,+14.2, +0.0,ECU.  , 694
 3003,+26.8, 574,100, 10,   00,  12.1,  25.4,+13.8, +0.0,ECU.  , 417
 3126,+26.8, 683,100, 10,   00,  12.1,  28.5,+13.4, +0.0,ECU.  , 750
 3267,+26.8, 769,100, 10,   00,  12.4,  32.8,+12.9, +0.0,ECU.  , 599
 3380,+26.6, 878,100, 10,   00,  12.3,  36.8,+12.8, +0.0,ECU.  , 666
 3542,+26.3, 984,100, 20,   00,  12.2,  41.0, +9.8, +0.0,ECU.  ,1106
 3695,+26.1, 976,100, 30,   00,  12.7,  42.2, +8.7, +0.0,ECU.  ,1190
 3822,+26.1,1077,100, 30,   00,  12.9,  51.2, +9.0, +0.0,ECU.  ,1256
 3982,+26.1,1136,100, 40,   00,  13.1,  54.3, +9.1, +0.0,ECU.  , 825
 4192,+26.1,1131,100, 40,   00,  11.4,  54.3, +9.1, +0.0,ECU.  ,1461
 4312,+26.3,1165,100, 50,   00,  11.7,  54.6, +7.5, +0.0,ECU.  ,1091
 4528,+26.6,1213,100, 50,   00,  11.7,  58.6, +7.0, +0.0,ECU.  ,1428
 4649,+26.3,1243,100, 50,   00,  11.6,  59.2, +7.1, +0.0,ECU.  ,1219
 4837,+26.6,1302,100, 50,   00,  11.5,  59.2, +7.2, -1.0,ECU.  ,1250
 4945,+26.8,1333,100, 60,   00,  11.7,  62.6, +7.4, +0.0,ECU.  ,1428
 5128,+26.6,1351,100, 60,   00,  11.5,  65.2, +7.7, +0.0,ECU.  ,1111
 5249,+26.8,1445,100, 60,   00,  11.4,  66.7, +8.2, +0.0,ECU.  ,1533
 5428,+26.3,1483,100, 70,   00,  11.6,  69.6, +7.9, +3.0,ECU.  ,1420
 5518,+26.3,1552,100, 70,   00,  11.1,  73.7, +8.3, +4.2,ECU.  ,1689
 5659,+26.6,1547,100, 80,   00,  11.1,  72.1,+10.2, +0.0,ECU.  ,1470
 5837,+26.6,1577,100, 80,   00,  11.6,  73.1,+11.4, +0.0,ECU.  ,1602
 5973,+26.6,1628,100, 80,   00,  11.5,  75.6,+11.7, +0.0,ECU.  ,1633
 6082,+26.1,1639,100, 80,   00,  11.3,  76.5,+12.3, +0.0,ECU.  ,1760
 6218,+26.3,1689,100, 90,   00,  11.6,  77.6,+12.5, +0.0,ECU.  ,1582
 6397,+26.3,1666,100, 90,   00,  11.5,  79.3,+13.7, +0.0,ECU.  ,1689
 6510,+26.1,1724,100, 90,   00,  11.5,  80.5,+15.0, +0.0,ECU.  ,1748
 6613,+26.1,1730,100, 90,   00,  11.5,  82.0,+15.5, +0.0,ECU.  ,1724
 6706,+26.1,1742,100,100,   00,  11.3,  82.6,+15.6, +0.0,ECU.  ,1811
 6844,+25.9,1760,100,100,   00,  11.5,  82.7,+15.8, +0.0,ECU.  ,1785
 6973,+26.1,1754,100,100,   00,  11.3,  84.2,+15.9, +0.0,ECU.  ,1760
 7047,+26.1,1760,100,100,   00,  11.5,  83.8,+16.1, +0.0,ECU.  ,1748
 7168,+26.1,1760,100,100,   00,  11.5,  83.0,+16.6, +0.0,ECU.  ,1798
 7278,+26.1,1779,100,100,   00,  11.5,  84.0,+16.9, +0.0,ECU.  ,1748
 7358,+26.1,1773,100,100,   00,  11.5,  83.4,+17.1, +0.0,ECU.  ,1748
 7473,+26.3,1792,100,100,   00,  11.4,  84.2,+17.2, +0.0,ECU.  ,1655
 7558,+26.3,1792,100,100,   00,  11.4,  84.7,+17.3, +0.0,ECU.  ,1712
 7751,+26.3,1798,100,100,   00,  15.2,  82.7,+17.7, +0.0,ECU.  ,1773
third gear pull.
was shooting to get around the 11.5 around 5k and up, good? bad?
running 20-21 psi.
thanks guys.
Old Oct 2, 2005 | 10:01 AM
joeymia's Avatar
looks good you can probally get more timing out of the tune. I am at 20 degrees by redline.
Old Oct 2, 2005 | 08:11 PM
dryad001's Avatar
Although you have more timing in the peak torque range than I do, by redline I am right around 23 degrees, assuming you run 93.
WarmPepsi
17
Sep 25, 2005 11:59 AM
SlowCar
10
Aug 4, 2005 07:29 PM
EVO8LTW
Aug 1, 2005 09:25 PM
TrinaBabe
15
Jun 27, 2005 12:16 PM
