ETA on timing control
Old Mar 1, 2006 | 11:46 AM
  #46
PVD04's Avatar
Originally Posted by TTP Engineering
Alright Paul, you are the brainiac. Help me find out what AIT voltage reading would be considered, warmed up.
What I want to try to do is setup variables for cold start enrichment which will allow you to turn it on, but not activate unless the AIT sensor is indicating that the air is cold or the motor is cool.
We could run this off of coolant temp, but that would require another tap to the ECU and I think we are out of wires.
Let me know your findings!
Looking through my logs and based off of the way the AIT varies, it would not be possible to adjust cold start with the AIT. I get near ambient AIT readings while cruising down the interstate, so I would end up with cold start enrichment activated during cruise. I think the only way to effictively do this would be with coolant temp.
-Paul
Old Mar 1, 2006 | 11:59 AM
  #47
TTP Engineering's Avatar
-Paul
Cold start is something that only activates on startup and then tapers out depending on the tuner's settings for enrichment. Usually within a minute or two.
What I am implying is just way to disable it over xx temp at startup only.
So cruising would not make a difference because cold start enrichment would have tapered out to nothing long ago at that point.
Basically when you shut down your hot motor and let it sit, the AIT sensor would have to register this radiant heat. If you find the threshold we can have the MAFTPro look for the temp and not engage over xx voltage or 85*F or something along those lines.
Old Mar 1, 2006 | 01:36 PM
  #48
PVD04's Avatar
I see what you are saying. My other concern is how it reacts during hot summer days. Because I haven't used the MAFTpro in hot weather yet, I'm not sure if cold start enrichment will be needed. A lot of this would depend on ambient temp. If it is -10 and windy outside, I could shut my engine down and within 2 minutes the AIT could be reading 30 even though the engine would not need cold start enrichment if it were restarted. If it were warmer, the AIT threshold for cold start enrichment to be turned off would be higher. It may be possible to do something like this, but it may require frequent changes depending on ambient temperature. Ideally we would have a coolant temp input and could adjust based upon that. I can do some logging this weekend to test out the AIT readings after shut down. My laptop took a dive into my passenger footwell earlier this week and is being replaced on Friday. Once I have it back I can do a bit more testing.
-Paul
Old Mar 24, 2006 | 06:25 AM
  #49
thatsMR2u's Avatar
any updates on timing?
Old Mar 24, 2006 | 05:25 PM
  #50
dryad001's Avatar
-Paul
Well I have tested both. Up in the northern states the enrichment works wonderful. When I was in FL 2 months ago I didn't notice a richer condition during warm-up.
Carloverx
Mar 2, 2020 12:21 PM
Solarwater
27
Jul 16, 2013 05:48 PM
urnamehere
11
Jan 10, 2008 03:58 PM
EVIL_EVO_VIII
20
Mar 10, 2006 09:50 PM
SIMSSEGA
Lancer Aftermarket Forced Induction Tech
21
Aug 10, 2005 09:43 AM
