intercooler tune?
Old Mar 23, 2006 | 09:37 PM
mchuang's Avatar
Originally Posted by Excalibur
I currently have a BR TBE, BR cone filter, BR MAF PIPE w/ Breather filter, BR UICP, BR mini battery, 1g bov, dyno flash, SAFC II w/ Buschur settings, turbo xs MBC.
My question is, I'm planning to install the BR racing intercooler with lower intercooler piping, Will I need to install a 255lph fuel pump or not? I'll be running stock boost. Also, if I don't need the fuel pump, will I need to retune or will it be ok til I get my data logger?
You pretty much have the same mods I have, and I have the mail in flash. I was still running very rich with those mods, 10.7afr to be exact and I do have a walbro fuel pump. I used the afc to tune to 11.1. Running about 16 degrees @ 7000 rpm 20 psi. You probably wont have to retune, but I am running boost off ecu @20psi flat so not sure. Just borrow a wideband and dial it in.
Old Mar 23, 2006 | 09:51 PM
Danny23's Avatar
with your mods i,m suprised Al tuned you without a fuel pump, you should get it for sure. and you dont need to be retuned with the ic piping
Old Mar 23, 2006 | 09:53 PM
Danny23's Avatar
the intercooler has nothing to do with the tune
Old Mar 23, 2006 | 10:29 PM
Danny23's Avatar
thats why i,m suprised he tuned you without the pump,because of the intake,i could be wrong but he wont tune anyone with that setup anymore without a pump
Old Mar 25, 2006 | 07:28 AM
evoate ya's Avatar
I just installed the Buschur race front mount and it did affect my tune. It leaned the car by .3-.4 a/f, the cooler and denser air from the intercooler will lean out the mixture.
Old Mar 25, 2006 | 07:53 AM
bernardo's Avatar
PM importimage if you're looking for a 255 fuel pump. I got my Walboro w/install kit for $85 shipped 2 weeks ago. That price is hard to beat, and as you said you really do need a fuel pump at this point.
Old Mar 25, 2006 | 08:29 AM
mchuang's Avatar
My only problem is that I don't have any way to get it tuned when I put the intercooler on. I was thinking that if it would be safe to go ahead and put it on, I could get the fuel pump and take it somewhere that we could see what's going on b/c I'm still in the process of getting a datalogger. I just don't know if I would run too lean once the intercooler's on. The last time that the ecu was flashed was when I put the intake and tbe on.
What are you talking about, you have an afc. find someway to log air fuel with a wideband or get a pocketlogger and just try to get your af around 11.1 and you will be fine.
Old Mar 25, 2006 | 08:31 AM
Warrtalon's Avatar
He's taken care of and will get tuned properly for all of his mods on April 8th.
Dimas
Evo X Dyno Results
Feb 11, 2016 09:33 AM
legigon evo mr
13
Feb 9, 2016 03:47 PM
David Buschur
Sep 18, 2015 02:21 PM
legigon evo mr
May 31, 2015 11:39 AM
dinok
26
Mar 7, 2010 02:39 AM
