Do you realize?
Old Nov 18, 2005 | 07:51 PM
4TUN8's Avatar
Do you realize?
You could basically have anyone that is proficient with ECU plus tune your car via this forum? I think that would be pretty cool, make a pull, post the log, have some folks take a look at it and make their suggestions. Make another pull, etc.
I'm currently teaching myself and while I think I'm getting pretty good at tuning, I still feel like a newb, maybe doing something like this would give me and others more confidence.
What do you all think?
Old Nov 18, 2005 | 07:57 PM
Ev0ikon's Avatar
that is the idea of ecuplsy.com's forum :}
Old Nov 19, 2005 | 07:49 AM
4TUN8's Avatar
Oh, I've never seen anyone make adjustments to someone elses map on that forum....my bad, didn't mean to make it seem like I came up with the idea on my own, I figured it had been done already.
Old Nov 26, 2005 | 01:07 PM
RazorLab's Avatar
I'll offer my last log up for people to make suggestions:
http://www.norcalmotorsports.org/use...dynotest03.ecd
Mods:
TBE exhaust , cat delete
Fuelpump
720cc injectors
MBC set at 1.6 bar spike, holding 1.4bar
91 octane
If you want to play with the ecu + dyno my stats are:
05 EVO MR
3450lbs with me
255/40/17 tires
3rd gear
Old Nov 26, 2005 | 05:09 PM
4TUN8's Avatar
5500-6750 it's apparently knocking, atleast that's what it looks like to me. 1.6 bar is like 23.5psi isn't it? IMO that's WAY too much on 91, back that off to 1.4 bar and pull a log with the fuel set up like it is.
I'm not sure how normal +7 timing advance is on 91 octane, but on 94 I'm seeing 11-12 then it rises to about 18 at redline.
Old Nov 26, 2005 | 05:13 PM
RazorLab's Avatar
Woops, I should have wrote 1.6 bar spike. I fixed it in the post above. It spikes to 1.6 and goes down to 1.5 then holds 1.4bar. It is about 1.4bar at 5500+
but I do agree it's knocking, i've richend it up since then,
check this log out, I richened up 6000rpm by 5 points, 6750rpm by 8 points and richend over and under those a bit and it's actually looking it's knocking more.
http://www.norcalmotorsports.org/use.../Untitled1.ecd
Old Nov 26, 2005 | 05:15 PM
4TUN8's Avatar
I wish I had your injectors, I'm totally maxed out and forced to run like 19psi on 94 because my injectors hit 90+ just at 19psi.
Old Nov 26, 2005 | 05:24 PM
RazorLab's Avatar
You mean at peak trq? I would hit like only +3 before with the SAFC.
Old Nov 26, 2005 | 06:58 PM
4TUN8's Avatar
Look at the timing curve of some of the other guys logs....I've posted a few logs myself, although my car was knocking pretty decent it's self =p
Old Dec 22, 2005 | 05:47 AM
EVOLUTIONIZE's Avatar
http://www.ecuplus.com/forums/viewto...=17&highlight=
MitsuJDM
19
Nov 9, 2016 03:47 PM
Asmodeus6
Jun 9, 2016 09:26 AM
smanders
34
Mar 14, 2010 08:47 AM
dsevo
Dec 1, 2009 09:31 PM
MalibuJack
Apr 3, 2007 12:30 PM
