Hotside upgrade
Old Nov 21, 2005 | 01:33 PM
gaulrich2003's Avatar
Hotside upgrade
I have on 03" evo. How difficult is it to perform 05' hotside upgrade?
-Greg
Old Nov 21, 2005 | 01:34 PM
evilevovegas's Avatar
its a simple bolt on peice goes between your turbo and o2 housing. Try doing a search.
Old Dec 8, 2005 | 12:32 PM
Jeff_Jeske's Avatar
It took me about 4 hours......pretty easy but some of the bolts on the heat shield are difficult to remove and reinstall. I actually went out and purchased a zero swing ratchet for the job and that made life much easier.
Old Dec 8, 2005 | 12:35 PM
SLVRNBLK's Avatar
Veteran: ArmyFCOTM Winner
Pretty straight forward, basic tools required. Do it right and take the radiator off.
Old Dec 8, 2005 | 12:48 PM
AtO-MiX's Avatar
srry to go off topic but do you need a tune for the 10.5?
Old Dec 8, 2005 | 02:07 PM
spooledevo's Avatar
Like he said take the radiator out. It will save you time. It took me about 2 hours, but i have taken many of turbos off DSMs and Evos...
Old Dec 8, 2005 | 02:09 PM
EvoDan2004's Avatar
bump to this. and would you notice anything for the good or bad.
Old Dec 8, 2005 | 02:10 PM
housedj's Avatar
real easy, just make sure engine is cold since heat shield bolts are aluminum & snap with no effort. hotside will gain you about 15-20whp untuned. while u have the radiator off, it wouldn't hurt to also slap on a low temp thermostat...
Old Dec 8, 2005 | 02:25 PM
matt55's Avatar
IMO yes it would , on a stock ecu(piggyback/flash) it makes it run richer .
Old Dec 8, 2005 | 02:27 PM
Jeff_Jeske's Avatar
As for the tuning.....I have an xede computer....and the Vishnu told me to run an 05 map on my 03 car. I compared the maps and they are nearly identical. I wouldn't worry too much about getting a new flash for the hotside. There is a noticable jump in midrange torque. I didn't notice a change in spool. Very good mod for any 03/04!
tbaird58
Mar 18, 2017 03:51 PM
midegade
15
Mar 9, 2011 06:45 PM
black_beauty
18
Jun 21, 2010 07:11 AM
xmaciek82x
Midwest Region
Oct 17, 2009 09:07 AM
The442GTO
May 8, 2006 09:06 PM
