knock reading, how high?
Old Dec 15, 2005 | 11:11 AM
smp3000's Avatar
Hey guys, how high have you seen your knk reading go after a WOT?
Old Dec 15, 2005 | 11:26 AM
walkedu's Avatar
+1
Old Dec 15, 2005 | 11:49 AM
levo2nr's Avatar
the highist i ever so was 199 maybe 205
Old Dec 15, 2005 | 11:55 AM
smp3000's Avatar
Mine hit 208 this morning and then 180 this afternoon. Both were at WOT pulls to 7K... But keep in mind I'm only boosting 17psi.
Everyone tells me the SAFC-II knk reading is crap and to not go off of it. I was just wondering what other people have seen on their knk readings. I guess it also has to do with how you have your knock reading set???
Old Dec 15, 2005 | 11:56 AM
levo2nr's Avatar
how did u set u knock ?
Old Dec 19, 2005 | 08:42 PM
TTP Engineering's Avatar
I would set it to the highest count you can get under setup and then ignore anything under 100 after that. Over 100 and you will likely have "actual" knock.
We used a link electrosystems knocklink and timing datalogger for months to come up with this formula and believe it to be as accurate as could be asked for compared to any other data on this subject.
Old Dec 21, 2005 | 04:48 AM
smp3000's Avatar
Thanks for the post. How high would you guess the reading would be for audible knock? I know up to a point there is pinging that you can't even hear, but it is still bad for the engine.
Also, what do you mean- "set it to the highest count you can get under setup?"
Old Jan 7, 2006 | 07:04 PM
blowoffsilver's Avatar
thats my guess too the knock reading is **** but over 125 i would def start to worry
Old Jan 28, 2006 | 10:36 AM
Turbojunkie's Avatar
can you give a little more detail on this set up? sorry to be a pain, i would like know about this. thanx
Old Mar 12, 2006 | 05:47 PM
vone750's Avatar
+1
Old Mar 13, 2006 | 06:33 PM
Under the setup screen you set knock threshold. Rev and hold to the set RPM, keep resetting the SAFC until you reach one of the higher numeric knock settings and save it.
LVSBB6
Evo X How Tos / Installations
24
Oct 5, 2010 12:47 PM
ant_turbo
Apr 7, 2010 07:37 PM
villero1834
Lancer Engine Tech
May 14, 2008 01:01 PM
NRG
Aug 17, 2004 08:23 PM
pskelly86
Lancer Engine Tech
13
Apr 10, 2004 09:29 PM
