Flash with Revolvers???
Old Feb 14, 2006 | 01:10 PM
dsevo's Avatar
I am considering using a flash with the revolver cams I am putting in next week instead of the ecu+ that I already have. Will this work, and will the car idle? I will also be using 780cc injectors. I talked to Dan at HarmanMotive in So Cal, and he said it would idle lopey, but he could do it. Does this sound right, or should I use a piggyback? Has anyone used a flash for 280's or other radical cams and had success?
Right now with just the basic mods my car idles better, and drives better without the ecu+ installed, so this is why I am considering just using a flash. I also don't like that the ecu+ gives a CEL (but the cams will probably throw a CEL). Any input would be great. Thanks
Old Feb 14, 2006 | 02:46 PM
dsevo's Avatar
Someone must have a flash with one of the more radical cams. Anyone?
Old Feb 14, 2006 | 02:48 PM
EvoVIII_MR2005's Avatar
Even HKS 272's will idle lopey on just a flash, I have heard something that Al is tuning for now that gets rid of some of the lopeyness, but I have not seen it in person or heard a car idle with it.
Old Feb 14, 2006 | 02:49 PM
dsevo's Avatar
Yea, if 272's don't idle well, I'm sure revolvers won't. I don't care how it sounds, I just don't want it to stall at stoplights and such. Maybe I'll have to stick with a piggyback.
Old Feb 14, 2006 | 03:58 PM
jbfoco's Avatar
ecuteck will have no problems with revolvers i have a friend with a 3071 and another with a 3076 both have revolvers and ecuteck. With no issues.
Old Feb 14, 2006 | 03:59 PM
dsevo's Avatar
Thanks, I'll start looking into ecutek. I wonder if anyone in socal does ecutek? Thanks for your input.
Old Feb 14, 2006 | 04:47 PM
dsevo's Avatar
I called Harmon Motive again, and he did say that Ecutek would be better than a traditional flash. He said that with a 20g-9 and revolvers I am on the edge of needing a standalone, but a flash should still work. I think I want to stick with the stock computer to keep the drivability, and I'll just deal with the idle.
LetItBreath
36
Jun 28, 2013 05:36 PM
realrift
Oct 6, 2008 01:35 PM
steelcityevo8
30
Feb 4, 2007 02:54 PM
TwStDeVo
Aug 30, 2006 06:18 AM
rraulston
Feb 26, 2005 01:35 PM
