At what point is "Lean", TOO LEAN? With meth. also.
Old Sep 14, 2006 | 11:25 AM
DRFTKNGG's Avatar
Originally Posted by elhalisf
what about using windshield washer fluid?
Works...but it's like comparing 87 crap fuel to C-16 race fuel!
Methonal is cheap ...$30 for a 5 gallon can of VP meth. I mix the meth 75%meth, 25% H2O.
Old Sep 14, 2006 | 11:28 AM
TTP Engineering's Avatar
For most it is about $35-40 per 5gal.
It is too lean when you are knocking or exceeding 950*c EGT in an exhaust runner.
Old Sep 14, 2006 | 11:30 AM
nutrulz's Avatar
That's good to hear, Methonal is $25 per gallon here.
Old Sep 28, 2006 | 01:31 PM
blackdc5's Avatar
Originally Posted by SlowCar
distilled water from the grocery store. or if you know someone working in a lab with a deionizing system, 18Mohm water
How bad is tap water? I filled up w/ 100% coolant and some water from an outside faucet. I've had it in for about an oil change length by now. Should I flush it out again asap and how soon can it start to corrode the insides of the motor? (where the coolant flows of course)
Also, OT: what do you guys tune AF for during high load? If the OP is afraid of 11s, do you guys tune for 10? I tune my NA RSX, which is only 13.0 of course, and the FI K series people usually tune to 11 or 12 (11 AFR is less frequent though).
I ask because I am going to help my friend tune his EVO 9 w/ intake and 3" TBE.
Old Sep 28, 2006 | 04:39 PM
elhalisf's Avatar
evo 9's are very complicated to tune, especially with their 6 ignition maps and mivec control. it will be easy to tune the fuel maps, but thats not where all the power gains come from.
Old Oct 3, 2006 | 10:19 PM
EVO<VR4's Avatar
AFR at WOT:
10's factory
11's pump gas tuned
12's race gas/additive tuned
Old Oct 3, 2006 | 10:26 PM
Ultimate CC's Avatar
I too have found optimal gains with a 75% methanol mix and I keep my afr's on the richer side for daily driving with 11.6 down to 11.3 but I easily can lean them out more without any worries and the egt's remain within range...I do have to change my plugs regularly though...
Old Oct 7, 2006 | 06:59 PM
smokedmustang's Avatar
Originally Posted by EVO<VR4
AFR at WOT:
10's factory
11's pump gas tuned
Is this true??? This is what I was looking for. anyone else agree?
Old Oct 7, 2006 | 07:14 PM
Thats not very exact.
Old Oct 7, 2006 | 07:15 PM
whitey4d's Avatar
I try to stay aound 11.5-11.8 with 112 Sunoco. Im always knock free and have good EGTs with all the timing I want to add.
Old Oct 7, 2006 | 07:58 PM
How about "ballpark"?
Old Oct 24, 2006 | 03:27 PM
blackdc5's Avatar
Sorry to bump this, but I just saw his response.
6 ignition maps?
The RSX has 12 ignition maps, 6 for each cam angle 0,10,20,30,40,50, a set for both high cam and low cam.
Not to mention fuel maps for each of those cam angles on each low and high cam.
And variable cam angle (i.e. VTC)....isn't that what MIVEC is for Mitsu?
Raceghost
Nov 18, 2016 03:10 AM
HDGamer
Dec 2, 2012 12:39 PM
5LEEPERISAH23I
Jun 17, 2010 05:16 PM
navidf
11
Dec 22, 2008 09:14 AM
racer135
Aug 8, 2008 06:20 PM
