Knocklink sensor
Old Jan 17, 2007 | 01:22 PM
jusa4cyl's Avatar
Knocklink sensor
Has anyone used the SAFC to monitor knock. I was told it would do this. I lost my manual to the SAFC so I cant find out myself. Does anyone know about this? I was going to purchase the knocklink system but if the SAFC does it why buy it. I also need to know if I can keep the factory sensor or change it to a Bosch like the knocklink uses?
Old Jan 17, 2007 | 02:04 PM
Mellon Racing's Avatar
I can't speak for EVO but for the 3000/Stealth the SAFC's knock monitoring is useless
Old Jan 25, 2007 | 01:21 PM
jusa4cyl's Avatar
Any one else know of this!
Old Jan 25, 2007 | 01:31 PM
why don't you use EVOscan and setup a gauge to display knock, that's what I do.
Old Jan 27, 2007 | 05:29 AM
sparky's Avatar
Will you please explain what you mean by, "use Evoscan", and, "set up a gauge"? Does this require driving around with a laptop on the passenger's seat? The nice thing about the KnockLink device is that it has a really bright, eye-catching, red telltale light that indicates knock.
Edit: Maybe having both would be nice, because, I assume, the Evoscan method displays degrees of knock retard and has data logging capability, while the KnockLink device gives a warning alert, but no readout of the degrees of knock retard, and it has no datalogging feature.
Last edited by sparky; Jan 27, 2007 at 03:51 PM. Reason: retracting foot from mouth
Old Feb 11, 2007 | 09:59 PM
apexsilver9's Avatar
does anyone use the knocklite that some vendors sell. i dont remember who makes it. i was thinking about using it.
TTP Engineering
Sep 14, 2008 08:02 PM
evoate ya
Jan 10, 2006 01:58 AM
GDB
18
Dec 29, 2005 07:49 PM
joeymia
Nov 16, 2005 04:20 PM
porcupine
Jul 30, 2003 11:30 AM
