Stock Ecu Swapping????
Old Mar 22, 2007 | 07:10 AM
MalibuJack's Avatar
There actually has been some recent work done that documents some of the peripheral bits that will allow the ECU to ignore the Immobilizer.
However, it shouldn't be necessary, if you got your 4 digit Immobilizer code off your *OLD* Ecu that was working, and put that code on the new ECU, it will work.
When you Marry a new Immobilizer to an ECU, all its doing is taking the code from the new immobilizer and putting it into the ECU, when you marry new keys to the Immobilizer, it has NOTHING to do with the ECU.
Old Mar 22, 2007 | 02:16 PM
Slava's Avatar
No jack it did not worked! I copied immobilizer code from original ecu then i inserted it in new evo8 ecu and car will crank but guess what it would not start.
Then i send my rom to one person and guess what car will start with evo8 ecu.
So now i have ecu with deleted immobilizer function.
greddy23
Oct 27, 2016 10:12 AM
bbsevo
Jun 5, 2011 11:36 AM
get faster
20
Dec 9, 2005 06:59 AM
Ducheaven
Aug 1, 2005 06:28 AM
timdog4life
Lancer Engine Tech
Feb 22, 2005 01:59 PM
