necessary to tune for new setup?
Old Aug 27, 2007 | 05:29 PM
nyaegermeister's Avatar
How bad would i need a tune with a 10.5 hotside and ebay 02 housing added to my setup. I did search for a while on it but couldnt get a clear answer on if it was really needed for a retune for these. I'm sure the 02 housing wouldn't affect anything really but wasn't sure about the hotside.
Old Aug 27, 2007 | 05:31 PM
AL Beans's Avatar
yes......get a tune just like adding an exhaust or intake its a power adder
Old Aug 27, 2007 | 05:34 PM
EvoVIIIJeremy's Avatar
it will not hurt the car if it goes untuned but you will see more gains with a tune. just did the same mod then got tuned by AMS. Awesome
Old Aug 28, 2007 | 08:59 AM
Mellon Racing's Avatar
it's likely to push you into a higher load column and thus different fuel/timing values than intended. It might be a good idea to get it dialed in.
Old Aug 28, 2007 | 09:19 AM
TouringBubble's Avatar
I'm agreeing with Mellon. A good tuner would have anticipated the higher load values with mods, but it's not going to be 100%. If you have a solid tune currently, it's not absolutely necessary to re-tune right after the upgrade, but it would be recommended to do some logs and get it dialed in soon after.
Old Aug 28, 2007 | 01:54 PM
Thanks fellas, appreciate your advice.
Old Aug 28, 2007 | 02:07 PM
anytime
Old Aug 28, 2007 | 02:11 PM
Thegame's Avatar
I just did the same thing. I added a test pipe, O2 housing, ported ex manifold, and a 10.5 housing and my tune was way off!
luvboost
10
Apr 21, 2014 07:58 AM
Randal
Sep 18, 2013 06:30 PM
NOMIEZVR4
32
Nov 10, 2012 07:22 AM
GTijoejoe
Oct 10, 2011 07:06 PM
binh
Jul 26, 2009 12:42 PM
