Re-tune after 10.5
Re-tune after 10.5
Will i be ok to use my evo as normal after fitting a 10.5 hotside and titek o2 or should i not drive as hard until i get it re-tuned for the parts i just fitted.
You'll likely be hitting different load cells with the new mods, so it's best to at least do some logs before you go all out. If you have a solid tune currently with fully tuned maps, you might be fine.
