Detonation?
Old Feb 29, 2008 | 03:50 PM
Davedangerous's Avatar
Detonation?
While heading home from work this afternoon I experienced a loud boom. At first i thought i dropped the tranny. It happened when I started to get on the highway in 2nd pulled into 3rd 4th and in 5th is when i heard it. I immediately pushed down the clutch coasted for a few seconds and then threw it into 6th. I'm assuming that its because its pretty cold (19 degrees) and we're expecting some snow. not sure if its detonation...any ideas??
mods are cobb stg 2 93 ver100b
mr dp, mr test pipe, hks cbe
Old Mar 1, 2008 | 09:04 AM
i did some research and since i encountered fuel cut previously with the original map offered by cobb, it could have happened again. I went for another spirited drive and nothing. I'm thinking that I need to get a protune.
Old Mar 2, 2008 | 06:45 PM
RazorLab's Avatar
Sounds like fuel cut (boost cut)
Old Mar 3, 2008 | 07:52 AM
CPA5's Avatar
could the loud boom be attributed to an intercooler coupler coming off? although it doesn't seem so since you've driven it again and all things seem fine
Old Mar 3, 2008 | 11:53 AM
i originally didn't think that it was fuel cut because it sounded different, atleast i thought it did. as i mentioned before i think the freezing temperarure attributed to it.
Old Mar 3, 2008 | 12:31 PM
RazorLab's Avatar
The colder temp probably caused a boost spike or higher boost (which can be mostly tuned out via the boost tables) and it hit higher load and thus fuel cut.
Old Mar 5, 2008 | 07:59 AM
TheEvolutioner's Avatar
Definately boost cut, happened to me usually at 5th or 6th gear, @ around 5k rpms. Contact Christian at Cobb and he will hook you up with a revised map to stop to boost cut.
Old Mar 6, 2008 | 10:51 AM
i'm running the revised map, what i need is a protune
BoostingHard
13
Mar 27, 2017 10:49 PM
selp
Dec 12, 2014 09:10 PM
stunt2
Jul 20, 2011 02:59 AM
ikt
Jun 21, 2010 03:38 PM
Stew
141
Jun 6, 2006 07:45 AM
