Autronic with knock control!!
Old Jan 2, 2009 | 02:29 PM
diablo2184's Avatar
I know. That's why I called midnight EST
Old Jan 3, 2009 | 01:42 AM
casper980's Avatar
He didn't answer? I have never gotten a machine, he always picks up. You can call Richard too, he is always there, sometimes even later then the website says. I wouldn't wait for him to call back, just keep calling until you get him on the line.
Old Jan 5, 2009 | 10:11 AM
Mark S's Avatar
There are holidays in Auss so you may not get Richard till Feb, Not sure on Ian but its worth to try a few times without getting upset as he can be out tuning also.
Mark
Old Jan 7, 2009 | 07:34 AM
nitz's Avatar
any mention of individual cylinder retard with the knock module?
Old Jan 7, 2009 | 09:03 AM
Mark S's Avatar
Yes there will be.
Mark
Old Jan 9, 2009 | 05:58 AM
thebluesky's Avatar
Is this going to be a seperate unit available from Autronic, and will it be available for us PNP folks?
Old Jan 9, 2009 | 06:38 AM
Mark S's Avatar
It is for the SM4 based pnp unit and will plug in to the knock socket already fitted to the ecu.
Mark
Old Jan 10, 2009 | 06:35 AM
nitz's Avatar
Mark
and for the non-pnp SM4 guys?
Old Jan 10, 2009 | 07:38 AM
Mark S's Avatar
As far as I know but you would need to ask Richard or Ian at Autronic on it,
The Non pnp wont currently be avl as they are still trying to work out what is needed due to the diff engines this can be fitted to as they want to be sure it will work as it should on all engines,
The knock board may fit in the SM4 as I did ask about this a while ago but they were looking to amke sure if it was being used like this that it would only work on a engine with the same shap combustion chamber as tested on, i.e the Evo board would only be fitted and working on the Evo trigger pattern,
The other way to use knock control would be to fit the Evo Sm4 pnp from the 3 plug unit to a 4 plug Evo loom as this would work.
Mark
stevolution84
Feb 21, 2012 02:26 PM
crcain
33
May 9, 2008 09:52 AM
Ackerson
19
Feb 14, 2007 10:30 PM
evovette
Nov 13, 2006 11:30 PM
liberty2000rs
18
Sep 12, 2005 12:34 PM
