What are some must have gauges??
Old Apr 8, 2009 | 10:16 PM
boostedtres's Avatar
boost wideband oil pressure and egt if you want it. def boost and wideband first esp with your mods.
to above poster: you are right oil is monitored and not easily adjustable. however, unlike most cars, the evo does not have an oil pressure gauge stock. so yes, it is a extra safety mechanism. i have seen an oil leak right after a change. luckily, saw the oil on the ground before any damage was done. but had there been a oil pressure gauge, would have seen that pressure wasnt building and immediately killed the ignition. that engine almost seized up and went bye bye. its all about preference, mods, and what you will be doing with the car.
Old Apr 9, 2009 | 06:32 PM
Evo8=Life's Avatar
Will I looking into upgrading my gauges to Defi, Thanks for the input
Old Apr 9, 2009 | 08:09 PM
awdrivin's Avatar
EGT, oil pressure, boost, AFR
Old Apr 9, 2009 | 08:57 PM
dedlewamp's Avatar
I personally would pick a wideband over an EGT. Otherwise I'd go with a wideband, oil pressure, and boost.
Old Apr 10, 2009 | 10:26 PM
awdrivin's Avatar
EGT's can tell you just as much as a wideband
Old Apr 24, 2009 | 12:06 PM
k20toEVO's Avatar
Anyone know of a good boost oil pressure and wideband that light up red? And easy on the wallet haha (Brand and model)
I want to kinda make it look stock post some pictures up! thanks guys
Old Apr 24, 2009 | 07:28 PM
Walt's Avatar
Oil pressure is just an added security gauge to let you know if the motor is running correctly. all i have is boost and oil pressure for now. looking for wideband o2 i future hope soon
Old Apr 24, 2009 | 07:29 PM
Walt's Avatar
auto meter gauges are reliable
Old Apr 24, 2009 | 07:32 PM
Walt's Avatar
Yo anyone ever used an xtd ebay clutch please write me thanks
Old Apr 24, 2009 | 07:37 PM
eldiablo79's Avatar
Originally Posted by joyce1bro
you to be this guy
That's the same setup I have!
Old Jul 3, 2009 | 12:30 AM
BerserkerX's Avatar
Are you telling me that an EGT can tell me the exact AFR that I am running like a wideband???
I say boost, afr, EGT, and oil pressure are the ones you really need. Fuel pressure could help too.
Old Jan 12, 2011 | 08:30 PM
Greg555's Avatar
Volts - #1 gauge
Old Jan 20, 2011 | 08:31 PM
IraqFire88's Avatar
Veteran: Air Force
Egt is a little trickier to tune with is it not?
Old Apr 20, 2012 | 10:22 PM
hachansoo0413's Avatar
wideband, boost, oil pressure
Old Apr 21, 2012 | 07:24 AM
evo8426's Avatar
None! But I have a boost gauge, my wideband is wired directly to my ecu for logging only.
hussein
Feb 17, 2017 11:11 AM
Bman513
Jul 30, 2016 12:01 AM
EVOpena
Jan 25, 2014 05:21 PM
S2K2EVO
Sep 26, 2010 07:12 PM
lan_evo_mr9
Dec 14, 2006 07:08 AM
