Reading CEL
Old Apr 6, 2009 | 03:55 PM
mikespike2's Avatar
Reading CEL
I must be retarded.. I can't find any info on reading the CEL code.
Can I read it somehow with my tactrix cable?
How can I clear it?
Thanks!
Old Apr 6, 2009 | 03:56 PM
TeStUdO's Avatar
The newest version of EvoScan can read/clear Cel's.
Old Apr 6, 2009 | 07:59 PM
mikespike2's Avatar
Hmm, can mitsulogger? I don't have Evoscan yet.. Or ecuflash?
Edit: Just reflashed a saved map on there and it went away.
Old Apr 9, 2009 | 02:19 PM
acct918's Avatar
I'm still learning too, but anytime I flash a new map, the CEL goes away, but it will come back. I'm assuming it just resets it for a bit. There is a program called ScanTech that will tell you what code is popping up if your CEL is on.
Old Apr 9, 2009 | 02:30 PM
Mr. Evo IX's Avatar
Scantech and the newest version of EvoScan as previously mentioned. You can also just go to autozone and they can read your obd2 code. Disconnecting your battery or removing the ECU fuse will reset your ECU and clear the code, if the problem still exists it will come back. Reflashing does not do a ECU reset.
Old Apr 12, 2009 | 07:32 PM
mikespike2's Avatar
I reflashed and it went away, hasn't come back. Thanks for the advice, I have access to a scan tool but I was trying to do it with my laptop without having to borrow it.
CeeWhizzle
Feb 28, 2013 09:43 AM
Frew
Sep 11, 2012 10:51 AM
Mojito
13
Nov 9, 2010 11:24 AM
Davo
May 13, 2008 08:55 AM
premo
Jan 22, 2008 12:27 AM
