Dead Battery..Now Problems..Help!
Old Jun 7, 2009 | 01:00 PM
aguita's Avatar
Hello..
Yesterday my battery just went south and The car Died on me running..I replaced my battery but know my car is acting weird on idle..Mostly when the A/C is on the car idle then it goes stable..
I have a Power FC..Did my Tune just got lost or what?
My tuner said that I should use the car so this way it should learn again all the sensors
any help?
Old Jun 8, 2009 | 01:30 AM
seahawks12th's Avatar
idk how much i can help you but hopefully it helps a little. so my battery went out too and i replaced it. my car would only idle funny when it was warm or even if i just gave it a tiny bit of gas, it would drop the rpms really low then shoot to like 1200, then drop to like 700, then shoot back up, and even sometimes it would die. i went to a dealership, and they said it could take up to 40 ignition starts for it to relearn where to idle at, and now mine is fine after about 2 weeks. so i would give it a week or two before u panic. after 2 weeks get it looked at if its still doin it. as far as ur tune, i have no idea. i hope this helped a little
Old Jun 10, 2009 | 08:40 PM
aguita's Avatar
thanks for your help..car is still learning..hope this fix up soon!
Old Jun 11, 2009 | 04:13 PM
yea it took 2 weeks of driving a few times a day for mine, it might be longer or shorter for urs, but not by much.
Old Jun 29, 2009 | 06:41 PM
eflove's Avatar
I had this happen on my car with a power fc. The battery terminal came loose, I fixed it, and no idle. It ended up killing the idle circuit inside the ecu itself. I took the ecu apart and it looked fine but I tested the outputs at the ecu and iacv. The circuit was dead. I got a new ecu and it idles fine now.
Old Jul 6, 2014 | 08:50 AM
Dano8219's Avatar
Hi. Did replacing the battery affect your tune after all..? Just replaced mine on my Evo8 GSR an was wondering the same thing..
Lancerwinz
Apr 4, 2013 03:48 PM
EVOL2003
Sep 23, 2010 10:10 AM
Nevaeh
29
Mar 20, 2010 12:19 PM
aguita
Jun 20, 2009 08:03 AM
dsmbruno
11
Apr 16, 2008 07:22 PM
