Battery Dead On Me Problem!
Old Jun 7, 2009 | 01:12 PM
aguita's Avatar
Hello..
Yesterday my battery just went south and The car Died on me running..I replaced my battery but know my car is acting weird on idle..Mostly when the A/C is on the car hunts for idle then it goes stable..
I have a Power FC..Did my Tune just got lost or what?
My tuner said that I should use the car so this way it should learn again all the sensors
any help?
Old Jun 7, 2009 | 01:15 PM
chaotichoax's Avatar
your tune doesn't get lost if your battery dies
most evos struggle at idle with the a/c on
Old Jun 7, 2009 | 01:39 PM
EatSleepBoost's Avatar
if ur tune is off and ur fuel trims are horrible then it will re-learn them and fix ur tune for you itself. to an extent. when the battery is disconnected you will loose ur fuel trim adapts
Old Jun 7, 2009 | 01:46 PM
aguita's Avatar
thanks for the response..the car was idling HORRIBLE when I installed th battery...When I turn the A/C on the car almost stalled and the a/c compressor was going in/out intermitent..After a couple of drives the car is starting to work fine..Ill check out later...thanks
Old Jun 7, 2009 | 01:49 PM
Evokid8's Avatar
yeah your ecu needs to read everything again i had that problem
drove it for like 70 miles and it went away
Old Jun 19, 2009 | 10:06 PM
evo8um's Avatar
goodluck on everything you should be fine now
Old Jun 20, 2009 | 02:19 AM
bustriajb's Avatar
I know the 02-03 Lexus ES300's ran like crap after the battery went dead or when being changed. You have to like stomp on the gas just to keep it running for at least 10-15 mins. Then drive it like you stole it to get the ECU to relearn itself.
Old Jun 20, 2009 | 08:03 AM
xi0V3MR's Avatar
yea almost all cars when you disconnect the battery for long periods of time or even short periods of time, you'll need to start the car and just leave it sitting for about 10-15 minutes or until the fan comes on for the ecu to relearn the idle. you really arent suppose to be gassing the car, just let it sit on idle. its called the idle relearn process and was in the TSBs
aguita
Jul 6, 2014 08:50 AM
WarmMilk
Feb 5, 2014 06:29 PM
Lancerwinz
Apr 4, 2013 03:48 PM
X91EVO
34
Jan 23, 2009 05:16 AM
