TurnOver, No Start
Old Jun 10, 2009 | 11:27 AM
EvoVIII808's Avatar
TurnOver, No Start
ive had my PFC for a bit with no problems. i just got back from deployment and my friend was watching the car for me. He tried to drive on day and it was sputtering badly. i returned home and found 2 Vac hoses off. Fixed that, and tried to start the car. No Joy, it just turns over. Checked all fuses and found 2 bad (Eco sensors under the hood. 30amp)
Changed, and still no start just turns over.
Any idea what else it could be??
Crank sensor? Coils?
Ive gone through ever process i can think of except for changing these items.
Old Jun 11, 2009 | 04:30 PM
Dragon-V's Avatar
Hi
Is the display still showing on the commander as the battery/jump start or replacing fuse can spike the ecu and blow a fuse in it and this will stop the fuel pump from working and you will lose your map.
Old Jun 11, 2009 | 04:59 PM
EvoVIII808's Avatar
Everything still works on the commander. All sensors are good, all fuses replaced 2 days ago, and i checked again yesterday. Reset and installed the settings. Everything looks good with the ECU. Fuel pump primes, and can smell fuel when trying to start. Just not getting Spark. I dont have a CEL light or anything like that.
I think it might be a Relay, or the CAS sensor.
Old Jun 14, 2009 | 01:49 PM
EvoVIII808's Avatar
Is it possible for something inside the PFC to Bad. Checked plugs and getting spark on 1&3 nothing on 2&4
Old Jun 19, 2009 | 07:18 AM
sunnydaze's Avatar
Check to make sure that you are getting 12 volts to the coil packs......could be a bad IGN relay.
Old Jun 20, 2009 | 07:39 PM
EvoVIII808's Avatar
yup i just thought about that too. will check when i get home. got another problem to deal with now. My fuel pump is dead i think. No Prime, all fuses good and all relays replaced.
sounds like time for an Overhaul
Old Jun 21, 2009 | 04:25 AM
sunnydaze's Avatar
Yeah you always have **** like that to deal with whenever you park a car up for a while.
Old Jun 21, 2009 | 02:02 PM
EvoVIII808's Avatar
yeah, tell me about that. im still working the issues now, Gota get the size 8 for the fuel pump.
Old Dec 1, 2009 | 01:51 PM
VRSF Tiago's Avatar
Did you ever resolve this issue? I'm having the same problem.
Old Dec 18, 2009 | 03:52 AM
tonyp1025's Avatar
any news solving the issue...
Old Dec 18, 2009 | 08:33 AM
VRSF Tiago's Avatar
I fixed mine, was the crank position sensor.
Old Jan 6, 2010 | 12:13 PM
EvoVIII808's Avatar
sry to bring up old thread, but to close. It was the fuel pump. since it sat, i had to turn the over longer then normal, then it just fired right up. I found this in another thread here. Tried it, and it started.
Old Jan 15, 2010 | 08:46 PM
evolvd276's Avatar
Do you know if this works on the EVO 9?
Old Jan 23, 2010 | 02:49 PM
EvoVIII808's Avatar
It should. cars are basically the same, just some sensors added for the 9.
Old Dec 23, 2011 | 10:32 PM
BrOB2's Avatar
was it easy to change? gotta do mine, pulled cam and crank sensor code.... let me know
asu11
Apr 14, 2026 05:01 PM
06' Evo IX
Mar 3, 2020 11:42 AM
wazzelby
Mar 29, 2017 06:28 AM
lancerMXV6
Aug 20, 2013 08:06 PM
okevolutionVIII
Jun 11, 2012 09:09 PM
