E85 and 91 octane map switching
Old Jun 21, 2009 | 08:09 PM
Lucas03ES's Avatar
I am interested in buying an 04 viii gsr that is currently running on a tune with E85. One problem is that the nearest e85 pump is about ten miles away from me, so I figured if I had an option to switch between e85 and 91 octane maps, would it be possible? What exactly would be needed to set it up so with the flip of a switch and different gas in the tank (filled from near empty)it would work? Thanks
-Lucas
Old Jun 23, 2009 | 01:04 AM
SoCal Rally's Avatar
You will need:
1. Tephra patched ROM in your ECU
Read:
http://evoecu.logic.net/wiki/TephraMod
https://www.evolutionm.net/forums/ec...hramod-v5.html
https://www.evolutionm.net/forums/ec...6-testing.html
2. Way of switching between the 2 maps, either using the Intercooler Sprayer (ICS) switch, or an Alt-Map harness
Read:
http://www.dsm-ezine.com/evoVIII_adc_switch.html
http://www.dsm-ezine.com/orderpage1.html
3. ECU maps (fuel, timing, boost, etc.) for both fuel types.
weeeeeeeeee
Jun 27, 2016 04:01 PM
mrm95
16
Aug 25, 2015 10:26 AM
EvoX_BV01
Apr 23, 2013 09:35 AM
Rocky_RA
Apr 22, 2012 01:35 PM
Jim in Tucson
Aug 2, 2008 08:05 PM
